Old 11-16-2016, 08:06 AM   #1
nammie81
Drives: 2016 frs
wheel spacers question
4mm and 6mm wheel spacers on 18x8.5 +38 wheels
would this be safe to use on the stock nuts
or if anyone has a certain brand they would recommend
nammie81 is offline   Reply With Quote
Old 11-16-2016, 10:05 AM   #2
Icecreamtruk
Drives: Track preped NA FRS
4mm yes, 6mm might be dodgy. I have used 5mm spacers at the track on stock nuts with r-compound tires. If they can handly that, they can handle anything. But there really is barely enough thread, so 6mm might be pushing your luck.
Old 11-16-2016, 11:29 AM   #3
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
4mm = No
6mm = No
The stock studs are only safe up to a 3mm spacer.
If you want more, I'd highly suggest buying extended studs.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 11-16-2016, 11:44 AM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just got spacers with extended studs. They were only a bit more than just the spacer. Do it right and play it safe.
Old 11-16-2016, 11:10 PM   #5
nammie81
Drives: 2016 frs
i think i will just get extended wheel studs then
Wheel spacers vincelive123 Scion FR-S / Toyota 86 GT86 General Forum 6 01-16-2016 09:55 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 01:35 AM
Wheel Spacers Question bhbnuckle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-03-2014 12:54 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 05:11 PM
