Old 11-05-2014, 11:16 AM   #1
phrosty
Spacers with closed lugs
Looking to get some 5mm and 12mm spacers, and will need extended studs. I'm also in Chicago, so I need to deal with road salt -- I want to avoid rusting out open lugs.
Is anyone using closed lugs with extended-stud spacers? I wonder if there's a place I can order studs to a perfect size, or if I'd need to go big and find a way to cut them down.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 11-05-2014, 11:55 AM   #2
wparsons
wparsons's Avatar
You can try the nismo studs, not sure if they'll be long enough for 12mm spacers though. They're between the length of stock studs and ARP studs.
flickr
Old 11-05-2014, 01:25 PM   #3
DAEMANO
Time Traveller
Try Project Kics REVO 40s. They're extended open-ended studs but with caps (to keep gunk out of your threads). A few other mfgs are making these with caps as well.
Old 11-05-2014, 03:08 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Good idea, just cannot do this with 5mm spacers + ARP studs. Possible on 12mm, definitely OK with 15mm spacer.
The ARP studs extend around 7-10mm past end of R40.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
DAEMANO (11-05-2014)
Old 11-05-2014, 04:20 PM   #5
DAEMANO
Time Traveller
-alex
Good to know, thanks!
Old 11-05-2014, 04:51 PM   #6
phrosty
I'm using some Muteki SR35 right now. Sounds like I'll need to find out the required length and hunt on ARP/etc. for comparable studs.
The Following User Says Thank You to phrosty For This Useful Post:
BRZ RN (08-20-2015)
Old 08-20-2015, 12:54 AM   #7
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Which nismo wheel lugs will work for brz?
Sent from my SGH-T999 using Tapatalk
BRZ RN is offline   Reply With Quote
Old 08-20-2015, 06:58 AM   #8
wparsons
wparsons's Avatar
Do you want lugs, or studs? Any M12x1.25 lugs will work. If you're looking for the studs, not sure which ones are a direct fit, but Nismo definitely makes a set that works. I went with ARP instead.
flickr
Old 08-20-2015, 09:28 AM   #9
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
i meant nismo studs. is it any stronger than oem brz studs? i read somewhere that they are about the same material
Old 08-22-2015, 05:07 PM   #10
8R6
8R6's Avatar
Drives: FRS
-alex
Hey, would you also know how much longer the arp studs are compared to stock? I've tried searching on google and mfgr sites but can't seem to find the numbers...or maybe I'm just not searching the right words
8R6 is offline   Reply With Quote
Old 08-22-2015, 09:52 PM   #11
wparsons
wparsons's Avatar
It's much longer, if I remember tomorrow I'll take a picture of stock studs next to a pack of new ARP studs.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
8R6 (08-26-2015)
Old 08-26-2015, 11:31 AM   #12
mav1178
mav1178's Avatar
If you need to run any spacer larger than what the ARP studs can accommodate, you're doing it all wrong... but to answer your question, in terms of length it's over 1" longer than stock.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
8R6 (08-26-2015), DustinS (08-26-2015)
Old 08-26-2015, 11:42 AM   #13
8R6
8R6's Avatar
Drives: FRS
that would be super helpful! thanks man!
-alex
well that's what i'm trying to avoid. im trying to find out what the largest spacer that would fit on the ARP studs is, so i can stay below that limit. thanks for the answer on it being over 1" longer. im trying to decide between 20mm or 25mm spacers and wasn't sure about the 25mm fitment. thanks!
Old 08-26-2015, 12:28 PM   #14
mav1178
mav1178's Avatar
I fit 20mm spacers perfectly fine with plenty of thread. If I were to guess, 30mm is the max with ARP studs.
-alex
8R6 (08-26-2015)
FS: Muteki Closed End Lugs Chrome The Tengu Wheels and Tires 5 10-02-2014 07:48 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 10:46 AM
Muteki Closed End Super Tuner Lugs Reflex Wheels and Tires 2 10-03-2013 03:55 AM
Volk, Advan, Gramlights, SSR, Enkei, Project Kics, Muteki - Wheels/Lugs/Spacers No Limit Motorsport Wheels and Tires 25 11-20-2012 04:01 PM
