Old 09-18-2022, 09:17 PM   #15
Lantanafrs2
Drives: 2013 frs red
Cams sticking?
Lantanafrs2 is offline   Reply With Quote
Old 09-19-2022, 04:17 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Rako View Post
From my limited knowledge nothing really stands out except for the way the ignition advance is fluctuating. I am not a tuner/tuning expert so I can't really comment on how normal that is. IAM is steady, LTFT look fine, AFR is following command, no knock correction. I would think if it was an AVCS issue it would pop a code.
Old 09-19-2022, 08:58 PM   #17
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Would a bad crank sensor cause the timing to fluctuate?
Old 09-19-2022, 09:02 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not sure. I am not even entirely certain it’s not normal. It just looks odd to me.
Old 09-19-2022, 10:17 PM   #19
Rako
Drives: 2023 GR86 M/T
Yeah that's the thing, it looks normal for the most part..
Rako is offline   Reply With Quote
Old 09-19-2022, 10:18 PM   #20
Rako
Originally Posted by Lantanafrs2 View Post
Cams sticking?
How can you tell?
Old 09-20-2022, 05:43 AM   #21
Lantanafrs2
How can you tell?
I think a data log should show it. Sticky cams were an issue early on.
Old 09-20-2022, 10:39 PM   #22
makinen
makinen's Avatar
Drives: Toyota 86
There is a case that AVCS does not work but no code. It does not move even in the active testing in Techstream.
https://www.ft86club.com/forums/showthread.php?t=138803
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 09-23-2022, 08:13 PM   #23
Rako
Even if my logs show vvt enabled 1?
Old 09-23-2022, 08:28 PM   #24
Rako
I just dropped my exhaust to check for restrictions just because I had a cat go bad once and thought debris might be stuck in the pipe but nothing there. Rode around with muffler disconnected and also nothing changed.
Old 10-02-2022, 10:51 PM   #25
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
I haven't read everything, so I hope its not a repeat.
I would put a different, mostly basic map. One that will work for your exhaust and intake for sure, but just a basic off the shelf map from the car.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 11-28-2022, 01:12 PM   #26
Rako
UPDATE for anyone still interested
Flashed a stock 2017 ecutek map and I couldn't believe how much better the car ran. Even with the torque dip and all I have better acceleration and responsiveness and it's actually fun to drive again NOTE that I've ran 3 different tunes from 3 different reputable tuners (2 tuned it remotely and said everything looks fine) but all 3 have made my car run terrible before flashing the stock tune, which feels like an upgrade as crazy as it sounds. I'm positive the tunes aren't the problem and something else is f****** with me but what?
What gives?
I hope someone has a clue.
Old 11-28-2022, 02:07 PM   #27
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Very odd. My car throttle feels significantly better tuned vs stock, along with overall powerband.
My tuner switched me over to a euro ROM when I tuned with ecutek. Cannot comment on the exact differences between USDM and EURO ROMs as I don't have the technical know-how. Dumbed down answer I was given is that it's less buggy.
Maybe somebody can shed more light on the difference. @tomm.brz ?
Old 11-28-2022, 05:49 PM   #28
tomm.brz
Drives: brz 2017 hksv2
Bugs are related to racerom patch applied to >17 US oem map, so an unpatched rom as his doesn t have problem
i think it s case is that he just doesn t like the tunes he got from those tuners, and maybe the were not objectively well done oem tunes are very refined under 3000 rpm, and it s very much easy to mess up with smoothess and bogging down at low rpm if you don t spend time to improve it
any difference in power output between these two combinations of header+exhaust cats giorgi0424 Engine, Exhaust, Transmission 20 03-22-2016 03:36 AM
power output oft tunes denso Software Tuning 3 09-15-2015 06:53 AM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 03:54 PM
Inconsistent gear box? wootwoot Engine, Exhaust, Transmission 12 10-07-2013 02:15 PM
