Old 05-12-2022, 09:16 PM   #1
ihavefat
Drives: 2018 BRZ
Advice on installing JDL 4 2 1
I’m relatively new to the platform so I’d appreciate any advice :P
This is the guide I plan on using as a reference:
https://www.partsdocs.com/Guide/How+...+Subaru+BRZ/39
-renting the o2 sensor from autozone
-ordered the Grimmspeed gaskets for the header side. Will be reusing stock ones for the FP side or source one locally if available at the dealer
-my understanding is that I need to bang on the skid plate a little bit to conform to the header shape
-my torque wrench recently crapped out. Any recommendation on one?
-do I need bolts or can I just reuse the stock ones ?
Anything else I’m missing?
ihavefat is offline   Reply With Quote
Old 05-12-2022, 10:10 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Do you have a way to tune the car?
If not then don't install till you do have a way and a base tune.
The Following User Says Thank You to x808drifter For This Useful Post:
Wally86 (05-16-2022)
Old 05-12-2022, 10:23 PM   #3
Code Monkey
Drives: Subaru BRZ
Should have told me when you picked up the header; I am always happy to help with installs!
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
RToyo86 (05-12-2022)
Old 05-12-2022, 11:28 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
That is a pretty comprehensive write up, you should be fine.
I didn't need to massage the skid plate for my install YMMV.
From memory one or two of the nuts where the header meets the heads won't be accessible easily with a torque wrench. Getting the exact torque isn't critical though.
I was able to re-use existing hardware with my installation but I live somewhere that never snows so again YMMV.
As mentioned above you will need a tune with this header. I haven't seen an OFT optimised tune floating around so a reputable Ecutek tuner will be the way to go. If you are getting an E-tune make sure your tuner has tuned a car with this header before as the cam timing needed for it to run well is unique to this header.
1974 TA22 Celica
2013 86 GT
Old 05-13-2022, 11:30 AM   #5
Teseo
Drives: frs
Shiv have "optimized " tune for JDL but was for UEL... don't know if that tune could work on EL though
Old 05-13-2022, 11:35 AM   #6
PulsarBeeerz
Drives: JRSC BRZ SOLD
It will not.
PulsarBeeerz is offline   Reply With Quote
Old 05-13-2022, 05:52 PM   #7
ihavefat
Drives: 2018 BRZ
Yes, ordered the Ecutek yesterday from CSG and arrived today. I just sent over the car info to Zach.
Hahah, I appreciate the offer :P. You seemed busy with the track prep.
ah. Yeah..just wanted to make sure the nuts didn't back out lol.
QQ: Do people leave their OBD2 Ecutek bluetooth adapter plugged in? or take it out after using it?
The Following 3 Users Say Thank You to ihavefat For This Useful Post:
Code Monkey (05-13-2022), Wally86 (05-16-2022), x808drifter (05-13-2022)
Old 05-15-2022, 11:24 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
It wont. Totally different header.
1974 TA22 Celica
2013 86 GT
Old 05-15-2022, 11:27 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
I do. I got used to monitoring my trims etc so i use the app and Bluetooth functions.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
ihavefat (05-15-2022), PulsarBeeerz (05-16-2022)
Old 05-15-2022, 11:57 PM   #10
ihavefat
Drives: 2018 BRZ
Ah I see. Right, unless the car is in Ignition or On with the engine running, my phone can’t find the Ecutek via Bluetooth so I’d think it’s not draining the battery
So I got the header installed:
Got the base map loaded on and sent Zach the first datalog. I was able to torque down all the nuts except for the one on the passenger side, mostly because I couldn’t quite get the socket fitted. Ended up just using a ratcheting wrench to tighten it down. Let me know if anyone has a recommendation on fitting a socket somehow so I can use my torque wrench to torque it down.
Old 05-16-2022, 01:57 AM   #11
PulsarBeeerz
Attachment 211942
I was able to get a deep well 14mm and 6"(?) 3/8" extension on. First the socket on the nut, then slide the extension on between the runners.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Old 05-16-2022, 07:40 AM   #12
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Crows foot + extension maybe? (I'm just spitballing what I *think* I would do)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
ihavefat (05-18-2022)
Old 05-16-2022, 08:34 AM   #13
Code Monkey
Drives: Subaru BRZ
Assuming a 3/8" torque wrench, use a 3/8" to 1/4" adapter and you can sneak in a 1/4" extension between the runners, then put a 1/4" 14mm from the top.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
ihavefat (05-18-2022), Wally86 (05-16-2022)
Old 05-18-2022, 10:45 PM   #14
ihavefat
Drives: 2018 BRZ
I appreciate the help everyone !! I was able to properly torque it down.
I finished tuning with Zach and the car feels amazing. However, I haven’t modified the skid plate so I do hear a rattle sometimes. And I may or may not look for a catback as the car doesn’t sound that great with just the headers lol
Code Monkey (05-19-2022), Espi (05-19-2022), Wally86 (05-19-2022)
DIY-Installing JDM Underpanels-FRS/BRZ continuecrushing DIY (Do-It-Yourself) Guides 87 07-25-2020 02:40 AM
installing atf cooler HoonThis Engine, Exhaust, Transmission 3 06-05-2017 10:20 AM
Installing 18" wheels with spacers? Need advice? donjrian Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-15-2016 12:51 PM
Need help installing my avo turbo kit Astroboy Forced Induction 80 04-11-2014 11:03 AM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 02:17 PM
