Old 06-04-2017, 12:31 PM   #1
HoonThis
resident lunatic
HoonThis's Avatar
installing atf cooler
After installing an atf cooler, can you just add extra fluid to the sump while the car is running until the check hole drips or does a more involved process need to be used?
Thanks!
HoonThis is offline   Reply With Quote
Old 06-04-2017, 10:47 PM   #2
FirestormFRS
The cooler should tell you how much ATF to add. Can't hold more than a pint I'd think
FirestormFRS is offline   Reply With Quote
Old 06-05-2017, 07:05 AM   #3
HoonThis
resident lunatic
HoonThis's Avatar
Im going with a generic one (ie B&M) and adapting it so no instructions as far as that goes. Most cars are fine with just warmup and then adding, however I remember reading something about jumping some area of the fuse box to get it into a test mode and all this other nonsense just to do a fluid changeout... if thats the case, it almost seems easier to measure how much physically fits then adding it afterward.
Are there any decent threads on the subject? Ive found threads on mounting location and cooler choice but not much mentioning finishing up the install...
Thanks again!
Old 06-05-2017, 09:20 AM   #4
KDad2
KDad2's Avatar
Drives: 2013 Raven
http://www.ft86club.com/forums/showt...t=61498&page=7
Try this for the procedure. I haven't attempted this yet, but I plan on installing my transmission cooler as soon as I have a free weekend.
KDad2 is offline   Reply With Quote
Installing SBD Turbo Kit... CamFrs Forced Induction 13 01-15-2016 01:45 PM
Is installing an oil cooler dificult? Astroboy Forced Induction 9 05-23-2015 04:53 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 07:25 AM
