Old 09-13-2016, 05:58 PM   #1
donjrian
Drives: 2016 Scion FR-S
Installing 18" wheels with spacers? Need advice?
Hi everyone! Just joined the FR-S community around December 2015 and I'm starting to make mods to my car.
I ordered Volk TE37SL (http://imgur.com/a/8SJtv) with these specs:
Front - 18x9J +45
Rear - 18x9.5J +35
Lug - 5x114.3
I can't install them yet because my hub is still 5x100. Would you guys recommend using a conversion kit from Megan Racing or just using a wheel adapter/spacer?
Please advise on what would be the safest and efficient way to get my wheels on. I also wanted to know what tire size would be best for these wheels. I really appreciate all your help.
donjrian is offline   Reply With Quote
Old 09-13-2016, 06:05 PM   #2
gramicci101
Off Topic
Conversion spacers are typically at least 15 mm. Which means your wheels will now be 18x9+30 and 18x9.5+20. Those are going to stick out a LOT.
Old 09-14-2016, 05:07 AM   #3
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
Return them and get new wheels. You will not be able to get conversion spacers on those +35's without having a widebody kit.
Hostile_Kittens is offline   Reply With Quote
Old 09-14-2016, 08:27 AM   #4
Varelco
Drives: '15 GT86 & '22 GR86
5x114 hub conversion is your only option. With bolt on adapters they won't fit.
Varelco is offline   Reply With Quote
Old 09-14-2016, 08:28 AM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Why didn't you order the right bolt pattern?
Old 09-14-2016, 06:30 PM   #6
donjrian
Cause I'm an idiot.
Old 09-14-2016, 06:42 PM   #7
vincelive123
Drives: Scion FR-S
Yes return them. I use to have 18X9.5 in the front with a +40 and used a 5mm spacer. The spacer made the clearance just right with the springs. No rub.
vincelive123 is offline   Reply With Quote
Old 09-14-2016, 08:58 PM   #8
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
I run 18x9.5 +22 square. They could fit with spacer adapters, but you probably don't want to run stretch.
ChanceK is offline   Reply With Quote
Old 09-14-2016, 09:53 PM   #9
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sell them or return them
Old 09-15-2016, 11:51 AM   #10
ModBargains.com
ModBargains.com's Avatar
How bad do you want to run them is the big question, you will have to make some big sacrifices
ModBargains.com is offline   Reply With Quote
scion fr-s, spacers, volk, wheels and tires
19" Wheels/Tires Advice JR007 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 05-24-2018 10:52 AM
Help Installing "Kill Switch" carma143 Electronics | Audio | NAV | Infotainment 15 09-13-2015 10:44 PM
spacers needed after installing air ride? BRZ_Kamil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2015 02:21 PM
pics of stock wheels 1" drop and spacers atledreier Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-05-2014 02:04 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
