Old 02-21-2022, 09:21 AM   #1
Gallowlight
Drives: 2017 Toyota 86 860 Special Edition
Coolant gauge reading above normal?
Hi guys,
Just got some services done this weekend on my 2017 86. Changed the oil, rear diff and brake fluid. Usually my coolant and oil temps read at the first line. But when I left the dealer my coolant gauge started reading higher than normal. It's half way between the first and 2nd bars.
I drove back to Toyota and they put the scan tool on and there were no codes and the car was reading at 192 degrees. No signs of overheating, coolant levels were where they should be but the gauge is still high. Anyone have any similar experience?
Gallowlight is offline   Reply With Quote
Old 02-21-2022, 04:31 PM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by Gallowlight View Post
Hi guys,
If I recall correctly, this is completely normal. Your gauge was adjusted to view differently and not show the number values of your coolant. When this is the case, the middle region of the coolant gauge is optimal temperature I believe (in other words, where it is showing now is actually around 190F). If you are to change it back to show the number values, like your oil does, then you will see that it rises no further than around 190F (the first line). There is a simple solution to change this, by holding down a button. I am now leaving work so I don't feel like looking it up, but I can tell you that you should be fine!
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
Gallowlight (02-25-2022), Tcoat (02-21-2022)
Old 02-21-2022, 06:27 PM   #3
Chuckls
Moutain Runner
Press and hold the . or OK button on the steering wheel control to change the temp to F*. It'll drop back to 190*
Chuckls is offline   Reply With Quote
The Following 4 Users Say Thank You to Chuckls For This Useful Post:
2020BRZtS (02-25-2022), Dzmitry (02-24-2022), Gallowlight (02-25-2022), Tcoat (02-21-2022)
Old 02-25-2022, 04:26 PM   #4
Gallowlight
Originally Posted by Dzmitry View Post
If I recall correctly, this is completely normal...
Hey thank you! That was definitely the issue. It's strange that only the coolant changes and not the oil temp or voltage gauges. This is one setting I didn't know it had! I will let Toyota know for future 86 owners
The Following User Says Thank You to Gallowlight For This Useful Post:
Dzmitry (02-25-2022)
Is it normal that the coolant gets low in time? Busybee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 46 11-14-2019 07:20 PM
Normal MAP Sensor Reading's erebuswarrior Software Tuning 0 04-07-2019 09:22 PM
Boost Gauge reading low saikat.saha Software Tuning 4 04-05-2019 03:38 AM
Boost gauge not reading correctly Pneub Forced Induction 11 10-30-2013 01:39 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 04:17 PM
