Drives: Toyota Gt86 2012 orange
Boost Gauge reading low
Hi guys,
I am running 10psi on Greddy T518z according to my tumer report. But in boost Gauge it’s showing 5psi. 2 or 3 days ago it was okay. Suddenly it starts to showing 5psi constantly from 3k to 7k rpm. any suggestions?? Is it my map sensor is damaged or something else ( ** my tuning is going on still ) . Thanks Saikat |
Log manifold pressure direct with ecutek or oft.
See what that says Should be 1 bar or 14 psi with ignition kn engine off Should be 0.3 bar or about 4 psi engine idling Note reading is absolute ir reliative to atmospheric presdure |
Manifold pressure shows 1.7 bar with full throttle by ecutek datalog.
When ignition on and engine off it shows 1 bar. When idle it shows.7 bar as turbo has factory spring . I am using a ebc also Thanks Saikat |
#4 | |
If manifold presdure is ligging as 1.7 bar ful! Throttle thats 0.7 bar boost or about 10 psi. So looks like boost guage faulty or if its got its own pressure sensor its faulty |
Thanks .
You are right. It was a one way check valve problem in the boost gauge line. Thats why boost was leaking . Not it’s soleved . |
| Fuel Gauge - Incorrect Level Reading | soulreapersteve | Issues | Warranty | Recalls / TSB | 0 | 08-30-2016 11:28 PM |
| Perrin Boost gauge reading inaccurate? | oliverc | Forced Induction | 0 | 10-20-2015 11:26 PM |
| Digital boost gauge w/ vent pod grim speed boost controller | Meetjoeblack | Engine, Exhaust, Bolt-Ons | 0 | 03-09-2015 01:27 PM |
| Fuel gauge not reading properly | FR-S Hot Lava | Issues | Warranty | Recalls / TSB | 27 | 10-29-2014 10:33 AM |
| Boost gauge not reading correctly | Pneub | Forced Induction | 11 | 10-30-2013 12:39 PM |
