Old 04-07-2019, 08:22 PM   #1
erebuswarrior
Drives: 2015 Asphalt BRZ
Normal MAP Sensor Reading's
Can't seem to find any threads on here about how the MAP sensor normally reads while driving around and in manual's, what's the normal readings when clutch is depressed. I will be data logging MAP or manifold abs pressure probably tomorrow or the next few days, because I want to know where it normally reads when using the clutch. Once I know this, then I will be testing a possible afterfire or "pop" method with the (Ignition Retard when Clutch Down) as read in Ecutek, or in RomRaider with OFT tunes, (Ignition Timing Compensation Map Delta Clutch Depressed.) I'm hoping someone might already know what it should read when clutch is depressed before I start data logging the next few days. If no one does, I'll edit this post with my findings.
erebuswarrior is offline   Reply With Quote
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
Is this engine noise normal? (Consensus - normal) StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 31 02-05-2018 03:01 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
