#43 | |
Drives: 2013 Subaru BRZ
Another scenario that's apparently coming up is that it's rumored that they are moving the Camaro 1LE to FS from BS. That particular car will run all over pretty much everything in FS. These kinds of scenarios are not good for the SCCA because it's putting cars that are very expensive and better performing into classes where the traditional cars cost less and, of course, don't perform quite as well. I know I'll get plenty of detractors that will tell me I'm wrong but I don't think it's a good idea to take classes that are very well subscribed and introduce a car that makes all of the current participants obsolete. If the goal is to attract more members and drivers then this doesn't seem like a good idea to me. |
#44 |
Drives: '22 BRZ
I don't think anyone disagrees with you. I think the movement of the boost buggies to DS was a *huge* mistake, I enjoyed BS greatly in 2017 with my Focus RS. The initial reports that the CTR sucked were all in cold weather and they didn't get any heat in the tires so of course they sucked.
#45 |
Drives: 2022 BRZ
I feel like reguardless of where the new 86 is classed, it will be course dependent vs the current “overdog” in CS and DS
CS: ND is .5” down on wheel. 10-20mm less tire, and 40-50hp less but smaller foot print, and weigh ~500# less. GRZ will be better on power courses and possibly launch better at pros with more tire. plus from what my limited pro experience has been, they seem to favor power cars. DS: CTR will have 50-60 more HP, 20-30mm more tire 1” wider wheels, but larger footprint, 4-500# more, and a garbage trans. GRZ will be the better transitional car here and will for sure launch better than a CTR at a pro but not sure how they will stack up on index vs HS and STH (assuming DS is still a bump class for 2022 but attendance in 2021 makes it seem like it still will be) I think I’d almost rather see the car attempted DS for 2022 and go from there. |
| The Following User Says Thank You to MacSpeed For This Useful Post: | DocWalt (11-24-2021) |
#46 | |
Drives: 2022 GR86
Another factor is that NDs have better weight distribution for the first few feet of launches: 50/50 vs 53/47, higher CoM allows even more weight to be transferred to the rear. |
| The Following User Says Thank You to timurrrr For This Useful Post: | MacSpeed (11-23-2021) |
#47 |
Drives: Miata
#48 |
Drives: '22 BRZ
Center of Mass
FWIW CS NDs definitely launch better than street class twins, though they also struggle from wheelspin or wheelhop if you get it wrong.
#49 |
Drives: 2016 Scion FRS
I think pretty much anything modern and designed to be sporty launches better than the twins.
#50 |
Drives: '22 BRZ
As a side note, Steve Berrodin consistently had the best launches in his DS twin by revving HIGH and slipping the ever loving crap out of the clutch. The clutch still lasted ~70k miles IIRC and the engine died not long later, lol. Considering a clutch job is easy and not very expensive and it's faster... Seems worth it.
#51 | |
He still autocrossing? He blew up at the Finale in '19 and I don't think I've seen him since. |
#52 |
Drives: 2022 BRZ
I only have experience launching a twin one event I ran a SSC car and that sucked. It was either bog or tire spin. Figured a twin with more power and 20mm more tire would launch better lol
#53 |
Drives: 2022 GR86
#54 |
Drives: 2022 BRZ
#55 |
Drives: 2022 GR86
#56 |
Drives: 2017 BRZ series.yellow
| SCCA AutoX Classing... | Roadcone | Tracking / Autocross / HPDE / Drifting | 13 | 10-21-2014 05:02 PM |
| Carbon fiber hood & SCCA classing | TimR | Tracking / Autocross / HPDE / Drifting | 21 | 06-17-2014 12:27 PM |
| AutoX and classing | chappys4life | Tracking / Autocross / HPDE / Drifting | 16 | 02-20-2013 03:38 PM |
| Autocross next wknd for me! Interesting response re: classing.. | MarkRacerX | Tracking / Autocross / HPDE / Drifting | 42 | 06-18-2012 01:52 AM |
