#57 |
#58 |
2022 BRZ Limited 18x7.5 wheels should clear 17-20 PP brakes without issue.
Needs a 5mm spacer to clear the CSG V2 Brembo BM4 caliper. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | pinoy_dorifto (11-12-2021), timurrrr (11-08-2021) |
#59 | |
Drives: 2022 GR86
https://www.ft86club.com/forums/showthread.php?t=147495 Yes, but some wheel/tire combos that have no issues on 1st gens might have issues in the rear on 2nd gen, see the thread referenced above. They're 7.5" wide, same as Performance Package on '17-'20's though? |
#60 | |
Drives: 2022 BRZ, Red
Subaru Part catalog confirms same RUCA as previous gen.
Almost makes me think the changes to the rear may have affected camber gain or other alignment geometry, which may have an effect on the wheel fitment difference @trippinbillies40 is reporting. But its just a theory at this point |
| The Following 2 Users Say Thank You to Brock H. For This Useful Post: | Code Monkey (11-09-2021), Stonehorsw (11-09-2021) |
#61 |
Some ACS footage showing a clean lap, as well as comparisons to the 1st gen car in LONG straights. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ZDan (11-11-2021) |
#62 |
Drives: '13 Whiteout
#63 |
#64 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
How much Ethereum do you want to send me a CSG goodie bag?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#65 |
Drives: Some rust bucket
hey mike, i dont think i've seen you do a brain dump of your thoughts on the 2nd gen yet. specifically, in stock trim and how it compares with the 1st gen.
#66 |
#67 |
Drives: 2022 GR86
Any updates on the oil temp situation?
I presume you've switched to 5w-30 oil? The car still only has the OEM oil cooler? How much cooldown does the engine require throughout a typical track session, compared to e.g. tires and brakes? Do you plan to keep the OEM oil cooler, or install a separate radiator? |
| The Following User Says Thank You to timurrrr For This Useful Post: | jflogerzi (11-11-2021) |
#68 | |
Still on factory oil. Still on the factory oil heat exchanger Zero additional cooldown needed. Unknown, as I don't know what's needed. If you'd like to fund the R&D, I can probably get all of this done quickly, within a week. I'd need to hire a CANBUS expert to sniff and identify the relevant channels, as well as a fabricator to figure out an oil-air mounting solution, factory cooler delete, thermostatic plate solution, and line routing. I'm sure some time can be saved by having new existing GReddy and Jackson oil cooler kits on hand, but that alone is already easily a $5000 bill. Remember, I have to work a job too, and only have so much resources to put towards this car. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | timurrrr (11-11-2021) |
#69 | |
does ecutek from 13-17 work, or does the ecu need to be jailbroken to access the ecu tables? |
#70 | |
Ecutek doesn't even recognize the ECU. None of my existing hardware reads any data out of the ECU other than base channels. |
| Tags |
| nowforitbs |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | BRZ Second-Gen (2022+) — General Topics | 25 | 11-05-2021 12:22 AM |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 5 | 11-02-2021 06:57 PM |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 10:11 AM |
| Mike @ LSD Motorsports | JDMenrique | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 04-06-2013 08:13 PM |
| Mike at Czp | _F-R-S_ | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 12-01-2012 10:01 PM |
