Drives: '13 BRZ Limited
Battery issues
Hey all, anyone else had this happen? What could it be, how do I fix it?
#2 |
That is acid vapor coming out from the breather vents and coming in contact with the aluminum tiedown making aluminum sulfate. Wash it off then use baking soda to neutralize the acid wash again, dry, and coat with a battery spray from an auto parts store.
Watch and wash as needed. |
| The Following 4 Users Say Thank You to ls1ac For This Useful Post: |
#3 |
Drives: hyper blue
you might dip the ground lead in white vinegar for an hour.
batteries start gassing when the voltage drops below 12.4. you might purchase a sealed battery or one with a vent tube (and route the tube outside the engine bay) |
#4 |
TRACKBREAD
Battery issues
Clean up the terminals and apply dielectric grease to them, that’ll keep the battery from producing the blue crap under the positive terminal. It’ll help with the white/gray powder you’re seeing too, but that’s mostly a sign of undercharging. Check the voltage across the terminals when the car is off. If it’s under 12.5V, charge the battery.
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | DarkPira7e (09-12-2020) |
#5 |
Rust bucket enthusiast
and put the cover back on the positive side when you're done
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Yoshoobaroo (09-16-2020) |
#6 |
We live in such an imperfect world. No system is ever completely contained. No part that lasts forever. We have to constantly evolve to move forward. It is even said that order only comes from creating more chaos somewhere else.
Sent from my SM-G975U using Tapatalk |
| The Following 3 Users Say Thank You to p1l0t For This Useful Post: |
#7 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | p1l0t (09-12-2020) |
#8 |
ProCrastinationConsultant
mine broke off within the first week of owning the car. i feel that this makes it easier to view all of the fuses.
#9 | |
I mean, it takes 2 seconds to pull off, and conversely doesn't look great without it on there. But, I see your perspective
| The Following User Says Thank You to DarkPira7e For This Useful Post: | soundman98 (09-12-2020) |
#10 |
it had something to do with adding a 4 ga wire for an amplifier, so it didn't just randomly break, but shouldn't have cracked the way it did with the minimal forces applied to it..
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (09-13-2020) |
#11 | |
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (09-13-2020) |
#12 | |
#13 |
| The Following 2 Users Say Thank You to p1l0t For This Useful Post: | humfrz (09-13-2020), soundman98 (09-13-2020) |
| Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 01:55 PM |
| Intake or battery issues with winter starting | daiheadjai | BRZ First-Gen (2012+) — General Topics | 10 | 01-20-2016 06:25 PM |
| Winter Battery Issues? Advice? | GeorgeJFrick | Electronics | Audio | NAV | Infotainment | 17 | 01-12-2016 11:11 PM |
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 01:35 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
