Old 01-20-2016, 12:59 PM   #1
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Intake or battery issues with winter starting
So I woke up to a car that wouldn't start today. Alternator would click, and all the lights and radio etc would start, but the engine wouldn't turn.
Tried to do a bump start as well as my own power pack to jump start.
No dice.
Called roadside assistance, and they came by with a booster pack. It still wouldn't turn over until they brought a second booster pack to up the amps.
I drove the car for half an hour to charge, then visited Subaru of London.
They told me the battery was fine, and that it was because my Injen intake had come loose (the hoses, and MAF sensor) which caused the problem.
I'm still a bit skeptical, but we'll see. The reason I bring this up, is that they charged me $50 just to tighten two screws, and one hose clamp, (on account of it being aftermarket).
If this happens to you, try to tighten these things yourself and save the money!
Sent from my SGH-I747M using Tapatalk
daiheadjai is offline   Reply With Quote
Old 01-20-2016, 01:52 PM   #2
extrashaky
Drives: 2014 BRZ Limited
Sounds like BS to me. The intake is not going to affect the output of the battery. If it were a problem with the intake, boosting the amps available wouldn't have magically caused it to start.
Did you have a check engine light on before this happened? Do you have anything on the car that could cause a slow drain, like a Bluetooth OBDII adapter?
Oh, and by the way, by "bump start," did you mean you tried to roll start it and dump the clutch? I don't think that actually works with this car because of the way fuel is delivered, or rather not delivered when you attempt to roll start it.
Old 01-20-2016, 02:04 PM   #3
daiheadjai
daiheadjai's Avatar
Nope. No CEL though I do have an OBDII, iPod and a dash cam. But I unplugged those last night because I noticed it struggling to start in the morning the last few days. In the past, when I had intake issues, it would throw a CEL but this one didn't.
I agree though... I didn't really buy it either, but had to grudgingly pay.
Old 01-20-2016, 02:18 PM   #4
extrashaky
There has been discussion on the board about how weak the stock battery is. Some people have actually had them replaced under warranty, IIRC.
I recently left for week on a business trip, and my battery was dead when I came back. Luckily it was at home, so I just plugged in the charger and charged it back up. However, I've noticed a few slow starts since then since it's been cold. That, along with your story, makes me nervous. I've been considering swapping it for something better.
Old 01-20-2016, 02:24 PM   #5
daiheadjai
daiheadjai's Avatar
The tow truck guys suggested heavy duty red top batteries.
The dealer wanted to charge me $50 just to check the battery. I'm almost certain I'll be visiting the dealer again...
If you're under warranty it might be a good idea to keep an eye on it... And make sure you have stock parts on when you visit the dealer.
Old 01-20-2016, 02:28 PM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Our batteries are weak for a reason. They don't weight too much. Try using an actual lightweight battery and then you'll face real issues ...
Old 01-20-2016, 03:23 PM   #7
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
No dice.
Wow. This puts my dealership into perspective. I showed up with no appointment and they replaced my battery/etc after cold starting problems. Bill was $0.00.
If the intake is coming loose, I'd remove it (it shouldn't be?!?).
GeorgeJFrick is offline   Reply With Quote
Old 01-20-2016, 03:25 PM   #8
GeorgeJFrick
http://www.ft86club.com/forums/showthread.php?t=99895
Here is my thread from a week or so ago when I had my second dead battery under warranty.
Old 01-20-2016, 03:37 PM   #9
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Surprised they warrantied your batteries since they are considered a wear item. My original battery lasted exactly 3 years in the Arizona HEAT before dying. The car will "bump"start because I had to do that to start the car LOL.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 01-20-2016, 05:01 PM   #10
lupindub
Drives: Scion FR-S
They warrantied my batteries as well. First week after buying my 2013 FRS that was CPO, battery died on me. Went to dealership and had it replaced with a new one for free.
lupindub is offline   Reply With Quote
Old 01-20-2016, 05:25 PM   #11
daiheadjai
daiheadjai's Avatar
Actually, this seems to have solved a persistent lumpy idle I've had with the Injen. It might be a cure for the problems Injen owners have been reporting. I'm guessing from use, the screws started loosening (I have tracked it a couple times).
Plus I'm a noob wrencher so I definitely could've done a shoddy install.
Winter Battery Issues? Advice? GeorgeJFrick Electronics | Audio | NAV | Infotainment 17 01-12-2016 10:11 PM
Starting car afte winter / disabling fuel injection df.dima Scion FR-S / Toyota 86 GT86 General Forum 21 11-23-2014 12:54 PM
Issues starting Scalzo Forced Induction 98 07-16-2014 12:15 PM
BRZ Battery died, when I tried starting it it made a terrible noise. cmspooner Engine, Exhaust, Transmission 95 06-17-2014 11:08 AM
Winter battery disconnect Skye Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-23-2012 12:28 AM
