Old 01-11-2016, 11:51 AM   #1
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Winter Battery Issues? Advice?
So last year my battery died and I tried to trickle charge it; even bringing it in the house. Trickle charger just flashed bad battery or whatever. I got a few jumps but the battery kept dying. (Milwaukee/Mid-west). I took it into Subaru and they said I had a bad battery and replaced it.
So now my car is dead again, trickle charger says battery is bad again. I have to leave for business in the morning, so I can't leave the car at Subaru for a day. My wife's WRX charged from the trickle charger just fine (I left her lights on).
Do others have problems with the BRZ battery in the cold? Should I just buy a nice battery or is it a problem with the car? It's -4F in Milwaukee.
Battery recommendations? Optima red would be my default choice?
GeorgeJFrick is offline   Reply With Quote
Old 01-11-2016, 12:04 PM   #2
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
It doesn't get as cold here in NYC (especially not this year), but last year it was consistently around 0-20F and I left my car parked most of the time. Drove it on the weekends, with a 1-3 week gap in between. Battery never died even while sitting around that long.
So your situation doesn't seem normal.. What aftermarket stuff do you have installed if any? Any remote starters? Those drain battery pretty badly from what I heard.
PandaSPUR is offline   Reply With Quote
Old 01-11-2016, 12:09 PM   #3
GeorgeJFrick
All I have is an intake pipe with the sound delete (still stock filter box, etc). Nothing else.
Old 01-11-2016, 12:12 PM   #4
PandaSPUR
PandaSPUR's Avatar
I would go back to the dealer and get the battery replaced again under warranty before wasting your own money getting a battery. Somethings up with your electrical system, or you just got really unlucky with two bad batteries in a row.
Old 01-11-2016, 12:34 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
There may be something wrong with your electrical system. I have a 2013 FR-S with about 60k miles that is parked outside and it still started fine yesterday morning at -10°F on the original battery (with protesting sounds of course). The BRZ has more electronic components that the FR-S, however, so maybe one of them is causing a problem with battery life.
Old 01-11-2016, 12:55 PM   #6
GeorgeJFrick
I'm going to try and get the car to the dealership, it means I have to take the day off work. FFS. I now own 2 Subarus, and I am not impressed.
Old 01-11-2016, 12:57 PM   #7
PandaSPUR
PandaSPUR's Avatar
Did your dealer maybe add some third party anti-theft system? Something like that could be wired wrong and just draining your battery all day long. Some systems have GPS, motion sensors, glass break sensors, accelerometers, etc and will drain you like crazy too.
Either way, doesnt sound like its your fault at all, so make sure the dealer fixes it.
The Following User Says Thank You to PandaSPUR For This Useful Post:
GeorgeJFrick (01-11-2016)
Old 01-11-2016, 01:35 PM   #8
There is quite a list of guys on here that had bad batteries so it is indeed a known issue. You just seem to have had the bad luck of getting two.
My personal reaction at this time would be to go and spend $100 and get a really good after market one. Sure they should replace it under warranty but there comes a point where my time is worth more than messing with somthing.
GeorgeJFrick (01-11-2016), zc06_kisstherain (01-12-2016)
Old 01-11-2016, 01:38 PM   #9
toast
Drives: 14 BSP Edelbrock BRZ
I think the batteries that come in these cars suck. My car lives in my garage year round, no matter how could it gets outside the garage is maintained above 40 degrees. Lately I have been starting it around 50 and the battery is definitely turning the car over slowly. The other night I came out after work to a 20 degree car and I really didn't think it was going to start. It did, but it certainly didn't sound like a healthy battery.
In order for my dealer to do anything they are going to tell me I have to leave the car with them overnight when it is cold. Just buying a new battery is less hassle than my time is worth to mess with the dealer.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
GeorgeJFrick (01-11-2016), Tcoat (01-11-2016)
Old 01-11-2016, 01:38 PM   #10
toast
Simultaneous posts, simultaneous thoughts
The Following User Says Thank You to toast For This Useful Post:
Tcoat (01-11-2016)
Old 01-11-2016, 02:46 PM   #11
GeorgeJFrick
So I gave myself a jump start with the WRX (again). Decided I should see if I could get into and out of the garage with the snow/ice. Practice makes perfect. I was feathering the clutch and the car died; then slid back down out of the garage.
Picture a perfectly clean red BRZ sliding down an alley. I'm trying to stop the car, and it's going alright. But I'm going into the street no matter what. There is a dip before the street, where of course, the car stopped. Wouldn't start. The WRX is back in the garage, and my car is in the middle of the street. I had to push my car out of the hump, into a down hill. Anyways, I pulled it off and the car end up parked facing the wrong way. I pulled the WRX around the block and jumped it again.
I'm here at the dealership. They wanted to know if I had an appointment. I almost snapped. Is this just a horrible dealership? Or is this on Subaru?
I can't explain my mood; and now I'm pricing a lease on an Imprezza to drive in the winters.
My estimated wait is 2.5 hours.
Going to try and get some work done.
Old 01-11-2016, 04:30 PM   #12
GeorgeJFrick
I'm getting a new battery under warranty.
They are trying to determine if something is causing this problem or if I'm a battery killer.
Old 01-11-2016, 05:18 PM   #13
Chimera
Drives: FRS
so.. knock on wood.. but I still have my OEM on a 13 and its still working fine, and I have a sub, HIDs, LEDs, and other accessories all directly tied off mine.
Old 01-11-2016, 06:09 PM   #14
GeorgeJFrick
The stunning conclusion...
I asked to lease an imprezza wagon since I can expense it for work. For the third time, this dealership made no effort to sell me a car. I begged for a WRX and ended up driving 3 hours away to get one. They promised to come find me with the lease info, never did. 3 hours.
They replaced my battery, advised I use a battery tender, and .... maybe unplug that bluetooth OBD sensor. So the answer is "I'm an idiot. This dealership and I are perfect for each other".
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Body Shop issues, need advice. Inextirpable CANADA 14 08-15-2013 01:00 PM
need advice for winter tires!!! ShowTime_DW Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-25-2013 01:57 PM
Winter: Electric car & battery warmer install JSUB BRZ First-Gen (2012+) — General Topics 2 12-26-2012 11:55 AM
Winter battery disconnect Skye Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-23-2012 01:28 AM
