Old 09-12-2020, 12:51 AM   #1
jeconti
Drives: '13 BRZ Limited
Battery issues
Hey all, anyone else had this happen? What could it be, how do I fix it?
jeconti is offline   Reply With Quote
Old 09-12-2020, 01:54 AM   #2
ls1ac
ls1ac's Avatar
That is acid vapor coming out from the breather vents and coming in contact with the aluminum tiedown making aluminum sulfate. Wash it off then use baking soda to neutralize the acid wash again, dry, and coat with a battery spray from an auto parts store.
Watch and wash as needed.
The Following 4 Users Say Thank You to ls1ac For This Useful Post:
humfrz (09-12-2020), p1l0t (09-12-2020), soundman98 (09-12-2020), thomasmryan (09-12-2020)
Old 09-12-2020, 08:23 AM   #3
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
you might dip the ground lead in white vinegar for an hour.
batteries start gassing when the voltage drops below 12.4. you might purchase a sealed battery or one with a vent tube (and route the tube outside the engine bay)
thomasmryan is offline   Reply With Quote
Old 09-12-2020, 09:08 AM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Battery issues
Clean up the terminals and apply dielectric grease to them, that’ll keep the battery from producing the blue crap under the positive terminal. It’ll help with the white/gray powder you’re seeing too, but that’s mostly a sign of undercharging. Check the voltage across the terminals when the car is off. If it’s under 12.5V, charge the battery.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
DarkPira7e (09-12-2020)
Old 09-12-2020, 09:23 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
and put the cover back on the positive side when you're done
Yoshoobaroo (09-16-2020)
Old 09-12-2020, 11:20 AM   #6
p1l0t
p1l0t's Avatar
We live in such an imperfect world. No system is ever completely contained. No part that lasts forever. We have to constantly evolve to move forward. It is even said that order only comes from creating more chaos somewhere else.
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
humfrz (09-13-2020), soundman98 (09-12-2020), T-Steve (09-13-2020)
Old 09-12-2020, 11:48 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Had the same a while ago.
https://www.ft86club.com/forums/show...ostcount=20541
p1l0t (09-12-2020)
Old 09-12-2020, 12:24 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
mine broke off within the first week of owning the car. i feel that this makes it easier to view all of the fuses.
Old 09-12-2020, 01:11 PM   #9
DarkPira7e
DarkPira7e's Avatar
Damn. My car has had the engine out 4 times, battery has been out several times, and it doesn't have a scratch on it.
I mean, it takes 2 seconds to pull off, and conversely doesn't look great without it on there. But, I see your perspective
Old 09-12-2020, 01:22 PM   #10
soundman98
soundman98's Avatar
it had something to do with adding a 4 ga wire for an amplifier, so it didn't just randomly break, but shouldn't have cracked the way it did with the minimal forces applied to it..
humfrz (09-13-2020)
Old 09-13-2020, 01:11 AM   #11
What did you take it off with? -
soundman98 (09-13-2020)
Old 09-13-2020, 01:13 AM   #12
Oh, my ....... don't give up your day job -
JD001 (09-13-2020), p1l0t (09-13-2020)
Old 09-13-2020, 02:35 PM   #13
p1l0t
p1l0t's Avatar
Which one?
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
humfrz (09-13-2020), soundman98 (09-13-2020)
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Intake or battery issues with winter starting daiheadjai BRZ First-Gen (2012+) — General Topics 10 01-20-2016 06:25 PM
Winter Battery Issues? Advice? GeorgeJFrick Electronics | Audio | NAV | Infotainment 17 01-12-2016 11:11 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
