Old 05-04-2020, 05:53 PM   #1
Andrei
Drives: Leon4x4 PRECISION6466,buyng soonBRZ
strange pressure in the cooling system
Hello everyone
I have pressure in the cooling system, the fluid is going to the Coolant Overflow Tank, It will fill up fast and spit the water outside.
I have a brand new koyorad radiator, changed to a new thermostat, even tried a 1.3 bar cap (Check my cap also and its fine).
I was sure that the head gasket is leaking but I did the leak block test (with the blue water) and its fine (doesn't turn yellow)
(the car doesn't overheat, only after it spitting enough water)
now i'm stuck and don't know what to do, I don't want to take down the engine if I'm not sure that is a head gasket failure.
someone have a clue what can it be? or how to check from here
Thanks
Andrei is offline   Reply With Quote
Old 05-04-2020, 06:55 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you taken it to a shop? I only know of 2 things that cause pressure: expansion from heat, and external pressure from gasket blowby. How are you monitoring the car's temperature to be sure it's not overheating?
Old 05-04-2020, 07:03 PM   #3
An overfill can do that . It will eventually level out. Could be air as well but I put my money on overfill.
DarkPira7e (05-04-2020)
Old 05-04-2020, 07:59 PM   #4
DarkPira7e
DarkPira7e's Avatar
Can't believe I didn't think of this.... Thanks @Tcoat
Opie (05-05-2020)
Old 05-04-2020, 08:33 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Andrei View Post
Hello everyone
Thanks
Did you bleed it from the bleed screw on the heater elbow? The engine is so low compared to the heater that it won't circulate if you've got an air pocket there, and guess what opens the thermostat.
Yup, the heater bypass.
Unless you've got the overflow filled to the brim, I'd be surprised if this was an overfilled situation. Fill it to the FULL mark on the reservoir and up to the overflow port on the rad. If you've got the classic "Yellow Funnel" to fill up the rad that's OK, bleed it while it runs with the heater bleed screen and the funnel on it. If you can use a vacuum filler that's the best way to go.
The Following User Says Thank You to RZNT4R For This Useful Post:
ls1ac (05-04-2020)
Old 05-04-2020, 08:46 PM   #6
ls1ac
ls1ac's Avatar
RZNT4R Is running on the right track. Just to reiterate: A bubble in the engine will expand and push the coolant out. A method called vacuum fill will pull most of the air out and suck coolant in. This is the preferred method on new cars. Usually cycling the engine to temperature about six or 10 times will solve the problem. When you do this have the heater on.
edit: If you did a really poor job of filling there could be air around the thermostat and it will not let the thermostat open. There is a very small bleed hole that is designed to let air pass but it can take some time and the engine will usually get hot.
Old 05-05-2020, 02:14 AM   #7
^^^this^^^
You're most of the way there. Fill the air gap at the top of the radiator. Bleed the air off of the heater core. Heat cycle the engine again.
Let it cool.
Repeat until you see nothing but coolant under the cap when it's cold.
Old 05-05-2020, 02:23 AM   #8
Andrei
I was at 2 good mechanics,
I didn't overfill (the water was between the low and full)
even so the water will keep spitting outside until it be liters missing in the system
I did bleed it from the bleed screw and wait until the car was hot
and I checked the temperature using a special tool of the mechanic that connected to the OBD2 that tells exactly the temperature
Old 05-05-2020, 03:34 AM   #9
tomm.brz
Drives: brz 2017 hksv2
this misterious special tool is doing the same thing as a obd reader built with 10cents of components!
And how is the oil temp from obd when the coolant starts to overheat?
did both overheat at idle in the long term?
Old 05-05-2020, 06:10 AM   #10
RZNT4R
Oh, also, this is going to sound REALLY stupid...
You've changed your rad... are the shipping plugs out of the inlet and outlet? I once saw a guy get trapped by a shipping plug that was shoved really far in and he just hadn't seen it, result: no coolant circulation.
When its spitting out coolant, what's the radiator core temp? What are the hose temps? What are the fans doing?
The Following 5 Users Say Thank You to RZNT4R For This Useful Post:
DarkPira7e (05-05-2020), Lantanafrs2 (05-05-2020), Opie (05-05-2020), Tcoat (05-05-2020), Ultramaroon (05-05-2020)
Old 05-05-2020, 10:49 AM   #11
Andrei
I tried for two hours on idle and no spitting out coolant, so it doesn't overheat,
oil temperature i didn't check
I definitely takes out the radiator caps
I don't remember exactly, in 91 degrees the first speed fans starts and in 96 degrees the fast speed kicks in
hose temps I didn't check only by hand and after the thermostat open all the hose and the radiator are hot
Old 05-05-2020, 10:57 AM   #12
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Thermostat in backwards?
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 05-05-2020, 06:49 PM   #13
RZNT4R
So I am to presume that when the fans kick in high, it's blowing out a LOT of VERY HOT air? I've seen low circulating systems where the rad gets hot, but as soon as the fans kick in they drain all the heat out of it and blow cold air as the engine keeps getting hotter and hotter.
Thermostats typically don't fit in backwards.
Old 05-05-2020, 07:28 PM   #14
Grady
Grady's Avatar
You changed the radiator and now you have a problem????
Step one, take everything off that you just put on. (paying attention to how it was installed)
Step two, read manual on how to assemble.
Step three, assemble the correct way.
Step four, drink beer and pat yourself on the back for a job well done!
presure
Cooling System Not Holding Fluid romendiratta Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-03-2020 10:20 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 06:16 PM
Which part of the cooling system is this from? texasbound972 Engine, Exhaust, Transmission 9 04-12-2016 03:47 AM
No a/c but system has pressure ZionsWrath Other Vehicles & General Automotive Discussions 8 06-14-2015 03:43 PM
Bleed air from radiator/cooling system? OnionTou Engine, Exhaust, Transmission 2 03-28-2014 09:54 PM
