#15 |
Trust me, I'm the Doctor
Yeah, idle. Run the revs up.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#16 | ||
Frosty Carrot
Drives: The Atomic Carrot
I'd gladly be the test mule for this one if this weren't my DD and only vehicle. If there are spare alternators laying around, this would be a huge benefit to the community. I'm sure we could cover any round-trip shipping costs incurred.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#17 |
Drives: 2017 Camaro 1SS
DC Power are about the only high amp alternators I've seen that don't sacrifice low rpm (idle) amperage. All the others usually output lower idle amps than stock alts, so you only see the higher "rated" output at higher rpms
#18 | |
Drives: 2014 Scion FR-S, 1998 Honda Accord
Sent from my ONE A2005 using Tapatalk |
#19 |
Drives: FR-S 2013 Asphalt
I was running close to 3300watts. I used Singer but the alternator itself didn't seem to put out that much more power. I think a better custom solution would have been better. Maybe a larger truck alternator, but even with a custom case with mounts that will adapt to the frs motor would still require a new longer accessory drive belt.
So, you can get a little extra power from an upgraded alternator, but don't depend on it, even though you will need it. Combine it with larger/multiple batteries that are for audio and definitely run capacitors. |
#20 | |
Drives: Neptune Blue A6
| Alternator pulley torque setting?? | ahaghshenas | Engine, Exhaust, Transmission | 4 | 07-27-2014 08:03 PM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| Carbign Craft Alternator Cover | BugeyedWagon | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-04-2013 09:58 AM |
| Alternator pulley?? | xpicer | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-13-2012 08:54 AM |
| Weak battery or bad alternator from factory? | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 09-21-2012 02:17 PM |
