Old 02-26-2013, 02:13 PM   #1
AtlasMick
Drives: FR-S 2013 Asphalt
Alternator Options
For those of us running or looking to run massive amperage drawing systems, what alternator options are you considering?
I haven't seen any increased amperage alternators for the FR-S/BRZ/GT86.
Does anyone have a link to the stock max alternator output?
Some considerations:
Smaller diameter pulley on the alternator
Dual alternator installation
Replace with higher output ALT.
Any other suggestions?
AtlasMick is offline   Reply With Quote
Old 02-26-2013, 09:58 PM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i looked here for Scion TC alternators might be the same size. but i havent really considered buying one. im sure someone could chime in about whether it would work or not.
https://www.dcpowerinc.com/high-outp...2.4L+I4+2AZ-FE
FreshFRS is offline   Reply With Quote
Old 02-27-2013, 05:10 AM   #3
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Maybe look at Subaru replacement alternators, since it is a Subie engine.
kmbkk is offline   Reply With Quote
The Following 2 Users Say Thank You to kmbkk For This Useful Post:
SirBrass (04-10-2014), Sportsguy83 (02-27-2013)
Old 02-27-2013, 03:01 PM   #4
AtlasMick
Thank you FreshFRS and kmbkk!
I'm considering the second alternator setup. I'll have to look around in the engine bay to see where I could weld up a second alternator bracket. I'll post pictures later (likely Saturday) with the proposed spot for scrutiny and commentary.
http://powerbastards.com/proddetail....od=Fitzall-220
^ any opinions on this brand?
Old 02-27-2013, 03:05 PM   #5
SkullWorks
Drives: SSM LT MT BRZ
So apparently none of you looked at the alternator before asking this???
It says on the label of the alternator that it is a 130A alternator.
please be mindful that this car already has a significant load due to the 90-100V required to open the DI against upwards of 200 BAR fuel rail pressure.....
SkullWorks is offline   Reply With Quote
The Following User Says Thank You to SkullWorks For This Useful Post:
shiro (05-23-2013)
Old 02-27-2013, 04:22 PM   #6
AtlasMick
I own an Asphalt FR-S but yes, have not had a chance to look at the alternator due to workload. I was assuming it would be similar to most modern passenger cars, in the 90-110 range. 130 is surprising but you are saying the systems require this amperage? It is assumed the manufacturer will install an alternator that can run all the systems of the car simultaneously and then some, but not an excessive amount more. This is why almost always, for a big system build the alternator will need to be upgraded or supported to mitigate headlight dimming and reduced battery/alternator lifespan.
The system I am putting into this car crashed my alternator on my first build. Installed a high output, but still had headlight dimming issues, so I'm looking for advice and I will have a DIY for whatever I do to be informative for others with this vehicle wishing to install heavy draining audio systems or additional electronics.
So, this thread is about what is the best choice for this car (based on availability, cost, ease of use, effectiveness)
Old 07-07-2013, 11:34 PM   #7
jwjknorr
Drives: FRS 2013
Curious as well
jwjknorr is offline   Reply With Quote
Old 07-08-2013, 09:15 AM   #8
AtlasMick
Mike Singer Alternators is able to make a 275a stock alternator replacement.
Old 04-10-2014, 02:05 PM   #9
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Since I've used DC Power alternators before, they were my first choice. Here's the response I got from them:
Greetings ,
As much as I would love to do this alternator right now, unfortunately we can't. We may later in the future but I don't have an exact answer as to when that will be.
Thank you
Has anyone successfully installed the Mike Singer alternator or any others for that matter?
I've had good experience with Excessive Amperage, Nations Auto Electric, Mechman, and others. I've contacted Nations, but awaiting a response.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
FreshFRS (04-10-2014)
Old 04-10-2014, 04:27 PM   #10
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
How much more engine power does it take to run it, though? I doubt you can get that much additional amperage just by upping the alternator efficiency, and there's always TANSTAAFL to consider. That extra electrical power has to come from somewhere, after all.
^GT5 Replay Photo Mode^
Old 04-11-2014, 06:17 AM   #11
AtlasMick
Just got the Mike Singer 275A alternator last night, by hand it didn't feel all that much more difficult to spin. I see what you are saying. I'll have to ask how it's done.
The Following User Says Thank You to AtlasMick For This Useful Post:
SirBrass (04-11-2014)
Old 04-11-2014, 06:32 AM   #12
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Are we concerned about massive sub draw? I thought same some decent D10 charge caps do the trick I've tested a 5.1k audison with two 10" no issues or dimming etc when car was running... Unless you're going all out like a stereo comp set and don't want to run caps I don't see the need. (For now) anyhow.
Old 04-11-2014, 04:35 PM   #13
SirBrass
SirBrass's Avatar
Maybe higher spin rate, & improved efficiency?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Old 04-11-2014, 08:28 PM   #14
AtlasMick
Definitely has a higher spin rate. The pulley is somewhere near half the diameter.
I opted for the externally regulated version, so I have quite a bit more install work to do prior to having the Singer alternator operating. I hooked up the stock alt to an ammeter see what it's current output was at idle right after cranking. 30 amps.
Alternator pulley torque setting?? ahaghshenas Engine, Exhaust, Transmission 4 07-27-2014 08:03 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Carbign Craft Alternator Cover BugeyedWagon Cosmetic Modification (Interior/Exterior/Lighting) 12 01-04-2013 09:58 AM
Alternator pulley?? xpicer Scion FR-S / Toyota 86 GT86 General Forum 2 10-13-2012 08:54 AM
Weak battery or bad alternator from factory? empower-auto Issues | Warranty | Recalls / TSB 2 09-21-2012 02:17 PM
