#15 | |
Drives: Brz
Any other areas I should take apart and check? |
| The Following User Says Thank You to FinallyGot For This Useful Post: | humfrz (03-20-2020) |
#16 | |
), and it needed a front strut, front spindle, front wheel bearing, front LCA, front wheel rim and a rear wheel bearing.So, once the alignment is set so it will drive straight, a road test should show if anything is whacked out. humfrz |
#17 | |
Drives: Brz
#18 |
He shouldn't be trying to get around town anyway. That is the whole idea of the lockdowns.
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (03-20-2020) |
#19 |
#20 |
Drives: Brz
#21 |
Well then should be driving back and forth not "getting around town,etc" as stated.
| The Following User Says Thank You to Tcoat For This Useful Post: | x808drifter (03-21-2020) |
#22 |
Famous Potatoes
Drives: '15 ultramarine
#23 |
ProCrastinationConsultant
dude. bro. dude.
#24 |
#25 |
If the guy is indeed a nurse and it isn't just a play for sympathy, he working so many hours he is so exhausted, he has obviously already substantially damaged his car at least once before, their combined mechanical skills can not figure out that a "bent" rear wheel means more than an alignment and there are no "tie rods" on the rear and they think they can bandage this all together then I think he should be looking for alternative transportation for the duration of this situation!
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#26 |
Wha'd I miss, bro?
#27 |
#28 | |
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (03-21-2020) |
| Need to replace bent OEM '13 wheel. Best option? | LudwigMiles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2017 11:27 PM |
| PSA: Don't drive like me (unless you want a bent wheel) | mav1178 | Tracking / Autocross / HPDE / Drifting | 11 | 07-25-2015 03:37 PM |
| Really bent wheel or a repair rip off? | joshlx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 02-17-2014 01:04 PM |
| New Wheels Bent | Admired | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 39 | 10-20-2013 09:39 PM |
| Bent Rim | Sir Alex | Mid-Atlantic | 5 | 08-09-2013 03:34 PM |
