Old 01-12-2020, 10:18 AM   #1
T0rt0r0
Drives: European gt86
Third brake light connectors
Hi !
Does anybody know where i can find the third brake light connectors (for both light and car side) ?
Illustration of the light side https://parts.subaru.com/a/Subaru_20...10-847-01.html
I'm in europe and its really hard to find a gt in the junkyard unfortunately :/
Thanks for your help !
T0rt0r0 is offline   Reply With Quote
Old 01-15-2020, 05:01 PM   #2
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
The small blade connectors (both male and female), are standard pieces available at the local electronics shop. Was able to leave the factory wiring untouched and add the appropriate connectors to the wiring of my CDC Design Concepts 3rd Brake Light replacement.
tarzan_nojane is offline   Reply With Quote
Old 01-16-2020, 10:34 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Sumitomo/Yazaki 090 II Series, Unsealed, Two pin
I believe the one on the car is keyed. You'll have to find one that has matching key orientation or grind the keying notch off
EndlessAzure is offline   Reply With Quote
Old 01-16-2020, 02:53 PM   #4
T0rt0r0
Thanks a lot guys !
I will try to source these !
Old 01-25-2020, 11:17 AM   #5
T0rt0r0
So I bought these https://www.corsa-technic.com/catego...ategory_id=172 and these https://www.corsa-technic.com/catego...ategory_id=207 in 2 ways.
They don't fit at all even though the shape looks similar (not a key history, they are really not compatible)
Did I miss something ? As shipping costs are too much I'll cut the wires and solder
Have a nice day !
Old 01-26-2020, 02:47 AM   #6
EndlessAzure
Wheels for Brains
They should look like this one
https://www.easternbeaver.com/Main/E...090/ts090.html
Here's an image from the light on my car. Notice that the keying is on the left (rather than on the right for the linked product). However, you can just grind the keying off of the one you buy, or buy a new male and female pair for the car.
I don't think all is lost. If you bought male and female of the new connectors, and you have new terminals, just replace both sides on the car.
Old 01-26-2020, 06:05 AM   #7
T0rt0r0
Thanks for the link !
Will see if I order some but this definitely help others
And yes you're right I could swap the car connectors with new ones but unfortunately I did not buy 4 connectors of each types of the links above but 2 and they are not compatible between them (not the same size).
I'm astonished that I can't find them directly in my country ...
Thanks again
OEM Tail light connectors aschnell Cosmetic Modification (Interior/Exterior/Lighting) 12 11-02-2021 03:02 PM
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More kashmir Exterior Parts (Aero, Lighting, Etc.) 7 12-11-2019 02:42 AM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
Corroded pins/connectors in light harness aegisdrgn Electronics | Audio | NAV | Infotainment 5 10-06-2014 08:04 AM
