Old 08-14-2019, 11:22 PM   #1
GrantedTaken
Need to bleed my brakes
Rented a car last week.
Brakes were TIGHT.
Realized my BRZ has a soft pedal.
Also, I don't want to deal with a sheared lug stud,
like the last time I removed a wheel.
I need to remove the wheels to bleed, right ?
GrantedTaken is offline   Reply With Quote
Old 08-14-2019, 11:35 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Brakes were TIGHT.
If it bleeds, you can kill it.
MS, CSCS, TSAC-F, CPT
Old 08-14-2019, 11:55 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I've done it on cars through the wheel or a classic reach around. You may be able to on the BRZ but I'm sure you would have to jack it up or train a 5 year old.
But really, just remove the wheels. The lugs are not made of chocolate.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
Ultramaroon (08-16-2019), wparsons (08-15-2019)
Old 08-15-2019, 01:22 AM   #4
Brakes were TIGHT.
First off, it's really not fair to compare the brake feel on two different cars.
Now tell me that you did check the fluid level in the brake fluid reservoir?
You don't have to remove the wheels, but it makes it easier.
You might consider using the "humfrz" method of bleeding the brakes:
Drive your car up to your local brake shop. Ask them to bleed the brakes. Have a cup of coffee and read a car magazine. Pay them $35. Drive home, Take a nap.
The Following 12 Users Say Thank You to humfrz For This Useful Post:
Busybee (07-06-2022), churchx (08-15-2019), JD001 (08-15-2019), korhun (08-16-2019), maslin (08-15-2019), Mr.ac (08-15-2019), soundman98 (08-15-2019), timurrrr (08-15-2019), Tristor (08-15-2019), weederr33 (08-15-2019), wparsons (08-15-2019), Yoko (08-15-2019)
Old 08-15-2019, 11:51 AM   #5
GrantedTaken
I take my cars to the shop for certain repairs I don't want to deal with.
But, I don't mind bleeding the brakes when I have time.
Only thing stopping me is a stripped lug stud and then dealing with a half day repair.
Old 08-15-2019, 12:27 PM   #6
Well, it seems like your call then.
If you use one of these, the lug nuts should come off without twisting off the studs.
Old 08-15-2019, 01:59 PM   #7
Grady
Grady's Avatar
Learn a better elbow torque or buy a torque wrench. Your studs should not be striping out from removing you wheels.
The Following 3 Users Say Thank You to Grady For This Useful Post:
Busybee (07-06-2022), soundman98 (08-15-2019), weederr33 (08-15-2019)
Old 08-15-2019, 02:48 PM   #8
wparsons
wparsons's Avatar
You'll need a helper to bleed the brakes, or a power bleeder, or speed bleeders.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Leonardo (08-15-2019), NoHaveMSG (08-15-2019)
Old 08-15-2019, 03:02 PM   #9
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Get a helper first, best if it is someone who is familiar with the brake bleeding process, then remove all the wheels and get the car on jack stands. Trust me, trying to do it through the wheel or without a helper is not a good idea if this is your first time bleeding brakes.
DandoX is offline   Reply With Quote
The Following 3 Users Say Thank You to DandoX For This Useful Post:
timurrrr (08-15-2019), Tristor (08-15-2019), wparsons (08-15-2019)
Old 08-15-2019, 03:38 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Who stripped the lug stud??
Old 08-15-2019, 03:42 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
https://www.amazon.com/Motive-Produc...gateway&sr=8-4
Easiest way to bleed brakes.
Old 08-15-2019, 04:08 PM   #12
GrantedTaken
I've bled brakes many times on all my cars.
The last time I removed a BRZ wheel, the lug nut got stuck using the impact wrench.
Had to use my breaker bar, and it twisted it off, and sheared the lug stud.
I had to install a new lug stud and lug nut.
Old 08-15-2019, 06:56 PM   #13
Sorry if I talked down to you, but, your first post didn't indicate (to me at least), that you had any experience bleeding brakes.
Old 09-07-2019, 10:24 PM   #14
GrantedTaken
I bled the brakes on the BRZ.
I was worried that the stud would shear again
but all lug nuts came off easily b/c of anti-seize last time.
I did about 10 pumps for the rear,
and 5 pumps for the front.
Brakes seem to be more firm, but still not hard & biting.
I think rotors are scored, and
I think the pads are low, but I can’t even see.
I literally had the wheels off, and I have no clue if the pads are low.
There is no where to see the pad. Totally blocked views.
How are you supposed to see if your pads are low?
Clutch fluid won't bleed. ML Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-19-2018 09:35 AM
DIY : How to bleed your brakes justinco DIY (Do-It-Yourself) Guides 4 09-05-2017 03:40 PM
How often do i need to change/bleed brake fluid (DoT 5.1) dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-15-2015 12:50 PM
Innovate Stage 2 intercooler bleed bakilman Forced Induction 4 06-13-2014 03:48 PM
Bleed air from radiator/cooling system? OnionTou Engine, Exhaust, Transmission 2 03-28-2014 09:54 PM
