| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2022 GR86
Hi folks,
I have a '17 BRZ with PP, and recently started looking for aftermarket wheels. To my disappointment, it turned out that those Brembos are so big that many wheels don't fit. On top of that, the available information about what fits was scarce. I even ended up ordering wheels that didn't fit — because I couldn't easily find any information that they don't ![]() I've decided to gather a list of known FIT (without spacers! 5x100 only), as well as popular DO NOT FIT wheels for these calipers. This list is combined from an old post by FT86SpeedFactory (thanks for the starting point!) and some random posts on this forum I've found. Feel free to post specs of wheels not on this list that clear PP Brembos (preferably with photo evidence that they clear) and I'll try my best to keep this list up to date for a while. Also please share if you know of some wheels that do not fit that might be of common interest (RPF1 17x9, I'm looking at you!). BRZ PP seems to have the same calipers as BRZ tS and 2004–2017 STi, this can be a good lead for more finds. Also attached is a template for "Brembo 1H4.6005A" you can use to check fitment. I believe it's for the "Brembo GT" calipers, not PP calipers, and Brembo GT's are known to be wider than PP. My understanding is that anything that fits Brembo GT should also fit PP, but I'm not 100% sure. This list is focused mostly on clearing the brake calipers. For other fitment questions (will it fit? will it poke? will it rub? will it hit the strut? etc.) it generally doesn't matter if you have Brembos or base trim brakes, so there should be more information on that on this forum, such as in the first three posts in this thread. Don't forget to use your own judgement before making a purchase — I'm just collecting what I find online, and I can't personally verify every combo / claim. Note that if one variation of the wheel is listed here as FIT, it doesn't guarantee that another variation will fit too, e.g. it's not uncommon for wider wheels to have more concave spokes than narrower wheels of the same model, causing issues on the hub-side edge of the caliper. Enough boilerplate, enjoy the list! In alphabetical order: 720Form GTF1 17x8.0 +35 DO NOT FIT GTF1 17x9.0 +35 DO NOT FIT (6 mm spacer might be enough) 949 Racing 6UL 17x8.0 (offset?) DO NOT FIT 6UL 17x9.0 +40 FIT Advan / Yokohama TC III 18x9.5 +45 FIT TC4 18x9.5 +45 FIT Advanti DST Storm S1 17x8.0 +35 barely fit, probably need a 3 mm spacer Ambit RE02 17x9.0 +35 FIT EVIDENCE/PHOTOS NEEDED! RS18 18x9.5 +38 FIT Aodhan Wheels AH02 18x9.5 +30 FIT, but a bit tight DS02 18x9.5 +35 probably need a 5 mm spacer APEX ARC-8 17x9.0 +42 FIT but some tires may have issues with stock suspension EC-7R 17x9.5 +40 FIT EC-7R 18x9.5 +40 FIT EC-7R other sizes almost certainly fit AVID.1 AV-20 17x8.0 +35 FIT AV-20 18x9.5 +38 FIT Barracuda Karizzma 18x8.0 +38 FIT? BBS RF504 17x7.5 +48 FIT, might want to use ~2-3 mm spacer RG345 17x7.0 +48 FIT Cosmis Racing MR7 18x9.0 +25 FIT R1 18x9.5 +35 FIT XT-005R 18x9.0 +25 probably fit? MORE EVIDENCE/PHOTOS NEEDED! DAI DW100, 17x7.5 +42 FIT Drag DR-38 17x9.0 +38 FIT Enkei PF01 17x7.5 +45 FIT PF01 17x8.0 +35 FIT PF01 18x8.5 +45 FIT PF05 17x9.0 +40 FIT PF05 17x8.5 +48 should fit? EVIDENCE/PHOTOS NEEDED! PF05 18x9.0 +42 (?) FIT Raijin 18x8.5 +45 FIT RPF1 17x8.0 +45 FIT (note that they have convex spokes for the 8" wide variant) RPF1 17x8.0 +35 FIT (note that they have convex spokes for the 8" wide variant) RPF1 17x9.0 +35 DO NOT FIT (need 8 mm spacer, but even then sit too tight) RPF1 17x9.0 +45 DO NOT FIT (more info welcome) RPF1 18x8.0 +35 FIT T6S 18x8.0 +45 barely fit, probably need a 3+ mm spacer TFR 17x8.0 +45 FIT TS-5 17x8.0 +45 FIT TS9 17x8.0 +45 FIT TS9 17x9.0 +45 FIT but a 5 mm spacer is recommended TS9 18x8.5 +45 FIT TS-10 17x8.0 +45 FIT TS-10 18x8.0 +45 FIT TS-V 17x8.0 +45 barely fit, probably need a 3 mm spacer ESR SR05 18x10.5 +22 FIT Fast Wheels FC04 17x8.0 +35 FIT FC04 17x8.0 +40 FIT Focal F20 17x8.0 +42 probably FIT EVIDENCE/PHOTOS NEEDED! Gram Lights / Rays 57CR 17x9.0 +38 FIT (might want a 1–2 mm spacer) 57CR 18x9.5 +38 FIT 57DR 17x9.0 +38 FIT 57DR 18x9.5 +38 FIT 57Transcend 17x7.0 +42 require 5mm spacers? 57XTC 18x9.5 +38 FIT 57Xtreme 18x8.5 +42 DO NOT FIT (fit with 12 mm spacers) 57Xtreme 18x9.5 +40 FIT the brakes but DON'T CLEAR STOCK STRUTS 57Xtreme 18x9.5 +35 FIT GTS GTS G709 18x8.0 +35 FIT JNC JNC002 18x9.5 +35 FIT JNC030 17x9.0 +30 FIT Kansei Corsa 18x9.0 +35 FIT Konig Ampliform 17x8.0 +40 DO NOT FIT, will require 5 mm spacer or even more Ampliform 17x9.0 +40 FIT Dekagram 17x8.0 +40 DO NOT FIT (5 mm spacer might be enough) Dekagram 17x9.0 +40 FIT Hypergram 17x8.0 +40 barely fit, probably need a 3 mm spacer Hypergram 17x9.0 +40 FIT Hypergram 18x8.5 +38 FIT might need a thin spacer (more photos) Ultraform 17x8.0 +40 DO NOT FIT (5 mm spacer might be enough) Kosei K4R 17x8.0 +36 FIT Mach V Awesome 17x9.0 +42 FIT EVIDENCE/PHOTOS NEEDED! Crucial 18x9.5 +42 FIT Wicked Awesome 18x9.5 +42 FIT EVIDENCE/PHOTOS NEEDED! Mak Rapide 18x8.0 +35 FIT? Veloce 17x7.0 +48 DO NOT FIT (need ~12.5 mm spacers) Method MR502 17x8.0 +38 FIT MOMO Heritage 6 17x9.0 +35 FIT Motegi Racing MR140 18x8.5 +45 FIT Option Lab Wheels R716 18x9.5 +35 FIT R716 18x8.5 +40 FIT OZ Ultraleggera 17x8.0 +48 FIT Ultraleggera 17x8.0 +35 FIT Ultraleggera 18x8.0 +48 FIT Prodrive GC-06H 18x8.0 +43 FIT GT1 18x7.5 +48 SNUG fit Rota G-Force 17x8.0 +48 seem to FIT KB-F 18x8.5 +44 FIT Titan 17x8.0 +?? DO NOT FIT EVIDENCE/PHOTOS NEEDED! Titan 17x9.0 +35 FIT EVIDENCE/PHOTOS NEEDED! Titan 17x9.0 +42 likely DO NOT FIT (need 3 mm spacers, might as well just get +35) Rotiform BLQ 18x8.5 +35 FIT KPS 18x8.5 +35 FIT KPS 18x9.5 +45 DO NOT FIT (need 3 mm spacers) Sparco Assetto Gara 17x7.5 +35 FIT Trofeo 5 17x7.5 +48 FIT SSR GTV02 18x8.5 +44 probably FIT, confirmation with Brembos would be great GTX01 17x7.0 +50 likely DO NOT FIT GTX01 17x8.0 +45 FIT, photo evidence would be great GTX01 17x9.0 +38 FIT GTX01 18x7.5 +48 likely DO NOT FIT GTX01 18x8.5 +44 FIT, photo evidence would be great GTX01 18x9.5 +40 FIT, photo evidence would be great Speedline Type 2013C 18x8.0 +48 FIT, confirmation with Brembos would be great Type 2110 17x8.0 +48 probably FIT Turini Type 2120 17x8.0 +40 FIT Turini Type 2120 17x8.0 +48 FIT Turini Type 2120 17x9.0 +40 FIT, confirmation with Brembos would be great Turini Type 2120 18x8.0 +48 probably FIT Speedwell RS-1 18x9.5 +45 DO NOT FIT need a spacer and probably don't clear stock struts RS-R 18x9.5 +40 FIT the brakes but DON'T CLEAR STOCK STRUTS Subaru non-PP BRZ wheels 17x7 +48 DO NOT FIT 2017+ BRZ PP wheels 17x7.5 +48 FIT (obviously) 2022 BRZ Premium 17x7.5 +48 FIT but 3mm spacer is recommended 2022 BRZ Limited 18x7.5 +48 SHOULD FIT, photos would be welcome 2004 STI 5x100 17x7.5 +53 FIT but see details 2011–2014 WRX wheels 17x8.0 +53 DO NOT FIT, need 3 mm spacers 2007-2008 Liberty GT SpecB Tuned by STI Enkei 18x7.5 +55 (part #ST2810021020, ST2810021030) FIT 2004 JDM Forester STI Enkei 18x8.0 +48 FIT V7 STI ??? FIT Superspeed RF03RR 18x9.5 +38 DO NOT FIT need 3+ mm spacer Titan 7 T-R10 18x9.5 +40 FIT T-S5 17x9.0 +37 FIT T-S5 17x9.0 +47 DO NOT FIT (need 5+ mm spacer) T-S5 18x9.5 +40 FIT Toyota 2022 GR86 Base 17x7.5 +48 FIT but 3mm spacer is recommended TRD TRD Forged 17x7.5 +43 FIT TRD 18x7.5 +35 may fit if those TRD calipers are the same size as PP Brembos — need more evidence. TSW Bathurst 17x8.0 +35 FIT Interlagos 18x8.0 +35 FIT Nurburgring 17x8.0 +45 FIT Nurburgring 18x8.0 +45 likely FIT, more evidence welcome TWS T66-F 18x8.5 +42 FIT T66-F 18x9.5 +45 FIT VarrsToen ES6 18x9.5 +35 FIT but might be too close Vision Cross 17x7.5 +40 FIT Volk Racing CE28N 18x9.5 +38 FIT EVIDENCE/PHOTOS NEEDED! Volk CE28SL 17x7.5 +48 FIT G25 18x8.0 +45 FIT more evidence welcome G25 19x9.0 +45 FIT more evidence welcome -- wait, do such wheels even exist? TE37 17x8.0 +40 LIKELY NEED 3mm spacer TE37 18x9.5 +36 FIT TE37 18x9.5 +40 FIT ZE40 18x7.5 +48 DO NOT FIT (need 5+ mm spacer) ZE40 17x8.0 +47 DO NOT FIT ZE40 18x8.0 +45 FIT WedsSports TC105N 17x8.0 +42 FIT According to CSG, the clearance is minimal, so you might want to use a 3 mm spacer. EVIDENCE/PHOTOS NEEDED! TC105N 17x9.0 +35 FIT TC105N 18x9.5 +38 FIT TC105X 17x8.0 +42 FIT According to CSG, the clearance is minimal, you might want to use a 3 mm spacer. TC105X 17x9.0 +35 FIT TC105X 18x8.5 +43 might fit, EVIDENCE NEEDED though! SA-10R 18x8.5 +45 FIT SA-10R 18x9.5 +40 FIT EVIDENCE/PHOTOS NEEDED! SA-10R 18x9.5 +45 FIT the brakes but DON'T CLEAR STOCK STRUTS WORK Wheels CR Kiwami Ultimate 17x9.0 +38 FIT Meister S1 3P 18x10.5 +14 FIT Yoshihara D-12C 18x8.0 +40 DO NOT FIT XXR 527 17x9.75 +25 FIT 550 18x8.75 +36 FIT Last edited by timurrrr; 10-22-2025 at 12:51 AM. |
#2 |
Enkei RPF1 17 x 8 +45
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits Last edited by 86MLR; 07-11-2019 at 04:30 AM. Reason: Brain farts were had |
#3 |
Drives: 2014 Subaru Forester
![]() TSW Nurburgring 17x8 +45 ![]() 2011-14 WRX wheels 17x8 +53 (3mm spacer required) Last edited by tehShirt; 06-22-2019 at 02:46 PM. Reason: added pics |
#4 |
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
These wheels all clear the Performance Pack Brembos:
Mach V 17x9" +42 Awesome ![]() Mach V Awesome 17x9" +42 Gunmetal ![]() Mach V Awesome 17x9" +42 gold Mach V 18x9.5" +42 Wicked Awesome ![]() Mach V Wicked Awesome 18x9.5" +42 gold ![]() Mach V Wicked Awesome 18x9.5" +42 Gunmetal Mach V 18x9.5" +42 Crucial ![]() Mach V Crucial 18x9.5" +42 gloss black Dan Mach V Last edited by Mach V Dan; 06-19-2019 at 11:50 AM. |
#5 |
Drives: 2022 GR86
#6 |
#7 | |
Drives: 2022 GR86
Only the "Crucials" have a photo with Brembos, and even then it's a tS (do those have the same calipers as PPs?). Can you please help us find photos of stock 17+ BRZs with PP with those wheels? Love the model names btw. |
#8 | |
![]() Dan Mach V |
#9 | ||
Drives: 2022 GR86
Hopefully someone in the future shares their photos with us, just because pictures are always good to have as extra evidence
#10 |
Drives: 2018 BRZ PP (Modified)
I have Gram Lights 57DRs in 18x9.5 +38. They clear the Brembos easily and give more clearance than the stock PP wheels.
#11 | |
Dan Mach V |
#12 |
Drives: '13 Scion FR-S & '17 Toyota 86
Speedwell RS-R in 18x9.5 +40. Fits with plenty of clearance! These wheels don't clear the OEM struts so you would need aftermarket coilovers to run them!
![]() Speedwell RS-1 in 18x9.5 +45 will also clear the OEM Brembo brakes! Pics coming at the end of this week! ![]()
#13 |
Drives: '13 FRS
TSW nurburgring 18x8 +45 should clear (https://photos.app.goo.gl/rJVdbDbjBpZQTLY67).
Note that I don't technically have the PP brembos but this cadillac/evo chimera (https://www.ft86club.com/forums/showthread.php?t=104730, https://www.ft86club.com/forums/showthread.php?t=117769) but the same sti sized rotors and similar sized calipers. |
#14 |
Photo for 57DR 17x9+38
No spacers needed.
| Tags |
| brz, performance package, wheels |
| Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 08:46 AM |
| Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 08:06 AM |
| Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 08:31 AM |
| What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 05:15 PM |
