Old 05-24-2019, 04:45 PM   #1
2Wavy
Drives: 2016 BRZ
What's actually holding the suspension together when you use an OEM crash bolt?
So i had crash bolts installed during my coilover install. I was wondering, what exactly is holding together the strut to the wheel bearing piece? If the hole in both the strut and the wheel bearing is 16mm, but the crash bolt is 14mm, what is holding the two in place? I get the clamping force is holding the bolt to the strut, but how is the strut being held to the wheel bearing piece if the bolt is smaller than both holes?
2Wavy is offline   Reply With Quote
Old 05-24-2019, 04:57 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Magic.
The Following 3 Users Say Thank You to JD001 For This Useful Post:
maslin (05-24-2019), Mr.ac (05-24-2019), ZionsWrath (05-24-2019)
Old 05-24-2019, 05:04 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
The friction from the clamping force. That's how any bolted connection actually works. Even with the 16mm bolt in 16mm hole, try loosening them both and wiggling things around- there's a good amount of play there.
jamal is offline   Reply With Quote
The Following 5 Users Say Thank You to jamal For This Useful Post:
2Wavy (05-24-2019), nikitopo (05-24-2019), Spuds (05-24-2019), strat61caster (05-24-2019), ZionsWrath (05-24-2019)
Old 05-24-2019, 05:36 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dude.....that's some good shit your smoking.
But seriously dude, pass that stuff over this way.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 05-24-2019, 05:49 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
https://en.wikipedia.org/wiki/Bolted_joint
ineedyourdiddly
Old 05-24-2019, 06:31 PM   #6
maslin
Benz Tech
Drives: 2017 BRZ Premium
Magnets?
maslin is offline   Reply With Quote
Old 05-24-2019, 06:37 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Just don't suggest that's how wheels stay on the car. All hell will break loose.
Captain Snooze (05-25-2019), soundman98 (05-25-2019)
Old 05-24-2019, 07:05 PM   #8
2Wavy
Drives: 2016 BRZ
So the two flanges of the strut are basically squeezing together the spindle and the friction keeps them in place? That makes more sense to me. So really the diameter of the bolt doesn't matter as long as it's thick enough that the bolt doesn't stretch right?
Old 05-24-2019, 07:13 PM   #9
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Why are you seeking logical answers?
Your high as fuck now.
Old 05-24-2019, 07:43 PM   #10
jamal
jamal's Avatar
Drives: Legacy GT
Bolts stretch when you tighten them. The important thing is having enough clamping force before the bolt starts to permanently deform or breaks (although some fasteners are designed to yield permanently at torque spec).
The OEM "16 mm" bolts are still M14 bolts, just with an enlarged shank. The threaded section is the same size and so are the torque spec and resultant clamping force. The larger bolt will stretch slightly less.
The Following User Says Thank You to jamal For This Useful Post:
2Wavy (05-25-2019)
Old 05-24-2019, 08:35 PM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Yep, bolts are actually springs. When you torque them down they stretch, preloading the spring/joint.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
2Wavy (05-25-2019), Tristor (05-25-2019)
Old 05-25-2019, 01:37 PM   #12
2Wavy
Drives: 2016 BRZ
Oh yeah true, I guess bolts wouldn't work as fasteners if they didn't have an elastic deformation range and the axial deformation is where the clamping force comes from.
Old 05-25-2019, 02:06 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Bolt use magic.
Old 05-25-2019, 09:54 PM   #14
86MLR
86MLR's Avatar
Red Loctite
Disclaimer: Don't use red Loctite
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 10:29 AM
Crash bolt nut size qoncept Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-03-2013 08:38 PM
Just installed crash bolt. normanb21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 05-21-2013 05:27 PM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 02:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
