Drives: 2013 WRB BRZ Limited
Broken ignition coil bolt
While changing my spark plugs I cross threaded the passenger side front ignition coil bolt. It broke off just above flush. How screwed am I?
2013 WRB BRZ
Gruppe-S headers|| Borla Cat back||OFT Stage 2+ |
#2 |
Pain in the ass but not horribly screwed.
https://www.aliexpress.com/item/5Pcs...E&gclsrc=aw.ds
#4 |
Yeah definitely cant get that in there, I'm afraid they are going to have to pull the motor....so I'm probably looking at 1k to repair?
2013 WRB BRZ
#5 |
Well ok then. Extracting the bolt is a pain in the butt. Getting to the bolt to extract it is even worse!
#6 |
$1100 to fix. That's for pulling the motor, replacing the valve cover because they couldn't get the bolt out and 2 new spark plug seals (whatever those are). I told them to just check everything at this point since the motor is out and I'm in this deep
2013 WRB BRZ
| The Following User Says Thank You to UNCC_BRZ For This Useful Post: | Tcoat (03-19-2019) |
#7 |
Site Moderator
Drives: ichi 86 Project
If you have MT, mind as well get stronger clutch fork plus newer TOB, if engine is out.
#8 |
Clutch and TOB were replaced <20k miles ago so I should be good. I'm having them check the pulleys because my engine is really chirpy on start up.
I also have a pretty unstable idle, it is all over the place from 500 to 1k , should i have them do that too?
2013 WRB BRZ
#9 |
Here are my plus vs new. Changed at 84k miles
2013 WRB BRZ
#10 | |
Drives: red 2014 FR-S
Is there enough sticking out to get vice grips on it? My next suggestion is cut a slot in the bolt with a cutting wheel on a Dremel. then get a slotted screwdriver bit in a ratchet. Have someone with a pry bar apply pressure to the ratchet head while you try to unscrew the bolt. Wouldn't hurt to soak it with a penetrating oil as well. The next step normally would be to drill out the bolt and put a helicoil in. You could try doing it with a right angle drill and stubby bits but I doubt it would be possible without lowering the motor. just curious, does the coil have to have a bolt on it? could you wedge something between the frame and the coil to hold it in place? |
| Ignition coil questions | hpde_addict | Engine, Exhaust, Transmission | 20 | 05-12-2017 11:34 PM |
| CEL P0351 Ignition Coil A | Exrald | Issues | Warranty | Recalls / TSB | 16 | 03-24-2017 12:09 AM |
| Ignition coil information | 1quickchic | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-12-2017 10:10 PM |
| Ignition Coil A CEL | Whats that smell? | Issues | Warranty | Recalls / TSB | 12 | 10-10-2016 02:09 PM |
| Coil ignition pack | D86Ellis | Issues | Warranty | Recalls / TSB | 7 | 09-20-2016 03:01 AM |
