Old 03-08-2019, 01:38 AM   #1
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Battery Recommendations?
Hey All - Quick question -
My OEM battery finally bit the dust (from my 2013) and it's time for a new one.
I track my car occasionally and am not opposed to getting a smaller / lighter one. I do store my car in the winter on a trickle charger, so very cold starts are not an issue.
IF I do go with an aftermarket, smaller/lighter batter - I want it to be almost a direct swap if possible.
Any recommendations over another OEM battery?
Thank you!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 03-08-2019, 03:03 AM   #2
JIM THEO
Drives: BRZ 2018
Shorai lithium battery, about 5lbs...
JIM THEO is offline   Reply With Quote
Old 03-08-2019, 03:29 AM   #3
Gopherboy6956
Any specific model?
Old 03-08-2019, 04:59 AM   #4
JIM THEO
Drives: BRZ 2018
Originally Posted by Gopherboy6956 View Post
Any specific model?
Something like this?
https://www.shoraidirect.com/en/p130...ty-case-type-3
It can crank even the winter if you use often your car
Old 03-08-2019, 05:06 AM   #5
JIM THEO
Drives: BRZ 2018
This thread may help you:
http://www.ft86club.com/forums/showthread.php?t=120937
Old 03-08-2019, 11:31 PM   #6
CraigVM
Drives: Car Collector
I went gel
I have some minor Audio equipment upgrades so went Gel to allow me Tunes / Movies without needing to keep the motor running.
CraigVM is offline   Reply With Quote
Old 03-09-2019, 12:23 AM   #7
Gopherboy6956
Where do you buy correct posts and such for it?
Old 03-09-2019, 12:29 AM   #8
Gopherboy6956
Also - following the thread that JIM THEO posted - it appears Shorai does NOT recommend using their batteries in cars yet. The gave some damn good reasons.
http://www.ft86club.com/forums/showp...8&postcount=14
Old 03-09-2019, 01:00 AM   #9
Gopherboy6956
After doing some looking - I think i'll go Braille AGM - still much lighter than stock, but no potential Lithium issues and I don't have to get a different trickle charger for winter.
Plus, around $200 still isn't bad.
https://www.braillebattery.com/index...atteries/b2618
Old 03-09-2019, 03:33 AM   #10
JIM THEO
Drives: BRZ 2018
Good point, actually I've read many forum members use it that's why I suggested it.
I think the max voltage I saw in my MY18 is about 14.4V, hope those that have it in their cars will comment with experiences!
Old 03-09-2019, 10:29 AM   #11
Tristor
Tristor's Avatar
Those "damn good reasons" really don't apply to our car. I've been running a Shorai LFX36 battery for a long time without any issues. I daily drive the car + track it. As long as you don't let it sit for a long time, you'll be fine. Our alternators do not overcharge, as long as you have the stock alternator. If you're doing crazy car audio stuff, probably don't want a lightweight battery to start with, but then maybe look elsewhere. Our stock audio stuff is not going to damage this battery.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
Spankopotomous (12-28-2020), why? (03-09-2019)
Old 03-09-2019, 12:06 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I live in a cold climate and have been happy with my switch to the PC680. I get a deal on Odyssey batteries, I paid under 150. It is about 60% the weight of stock, so not the lightest. But it is an improvement and my old battery had died on me anyway.
why? (03-09-2019)
Old 03-09-2019, 02:37 PM   #13
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Don't listen to Shorai, they don't know your use case. They assume you have some SUV with massive amounts of electronics. A Braille battery will have the exact same issues as the Shorai. The only difference is Braille takes the same type of atv batteries Shorai uses, relabels them, and doubles the price. The company that makes Braille batteries is called Deka, and you can buy the exact same battery for a ton less without the fancy Braille name.
why? is offline   Reply With Quote
Old 03-09-2019, 03:30 PM   #14
Gopherboy6956
I just bought a Braille AGM - not lithium. So going with the traditional tech that's just 1/3 lighter.
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
Auto Battery Recommendations? JGalp Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 10-08-2016 09:03 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
