Old 09-28-2016, 01:21 AM   #1
JGalp
Drives: 2015 CWP BRZ Limited
Auto Battery Recommendations?
Hey all,
just been a little past 2 years with the BRZ and I've noticed occasionally it doesn't start up right away. gonna call up Triple A and have them test it and the alternator.. i did some research and i heard Triple A is good for battery replacement, i don't know if this applies to all of Triple A but they use DEKA / East Penn batteries. i was told to stay away from interstate and Exide/Napa batteries because they switched manufacturing locations.
Can anyone give me any advice or recommendations for batteries? This is just for DD purposes. don't care about light weight performance batteries. Thanks!
John
JGalp is offline   Reply With Quote
Old 09-28-2016, 02:03 AM   #2
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
http://www.ft86club.com/forums/showthread.php?t=59790
Supposedly the battery is covered under warranty?
I have the same year BRZ as you and my dash cam killed my battery once. After a couple of days on a Battery Tender Jr, the car starts up quickly every time.
menikmati is offline   Reply With Quote
Old 09-28-2016, 06:50 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Go for a lightweight Braille battery. AGM batteries are a LOT lighter and smaller so you'll have to modify your battery tray & hold down. If you have a modified car and there's more vibration, there's the added benifit that AGM batteries are better at withstanding vibrations than lead-acid batteries are. They aren't as good against heat and if you discharge it (by leaving the lights on or whatever) they are harder to charge and take longer to bring back. And they cost more. Being in socal, they should be a great choice because even though Braille batteries have lesser CCA, you aren't in a cold place so it's not a problem.
Old 09-28-2016, 08:50 AM   #4
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by JGalp View Post
Hey all,
John
honestly if you don't care about weight then just get whatever is the best deal.
Old 09-28-2016, 09:55 AM   #5
This ^ Check the specs (I do not know them off hand) and get something that matches. I am usually in the "Buy the best quality and pay the premium" camp but since about 90% of batteries made are all done in the same two places then this is an exception to the rule. The only difference between MOST batteries is the colour plastic they use and the label they slap on it.
why? (09-28-2016)
Old 10-02-2016, 02:56 PM   #6
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Very little benefits in batteries, so just get one with a decent warranty. I have optima red tops because I have done great with them. Some say they are not as good any more for the cost. But I have had two last 8 years, and I changed them just because I did not want to take any chances. I have had Honda stock batteries go 8 years as well. I tell most people to just get that 100 Autozone battery or equivalent. Kirkland signature batteries at Costco are cheap and good.
Ernest72 is offline   Reply With Quote
Old 10-03-2016, 09:20 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
The costco kirkland and interstate batteries are good and cheap. I've begun running Odyssey lightweights in my cars (PC925) as they are lighter than stock, not too expensive, last longer, smaller...
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 10-03-2016, 12:35 PM   #8
qqzj
Drives: MDX, Camry
Does the lightweight Odyssey battery fit nicely in the battery tray? Thanks.
qqzj is offline   Reply With Quote
Old 10-03-2016, 02:13 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
Buying a battery through AAA is expensive. They charge you (rolled into the battery price) for delivery and installation. For the price of an AAA regular battery, I would get a much better AGM battery at O'Reilly's and install it myself.
MrDinkleman is offline   Reply With Quote
Old 10-03-2016, 09:26 PM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
AAA for batteries? And you are going to call them to test your battery? Wow
You do know they are not mechanics. The batteries they sell are dog shit, they are emergency side of the road, get you to your place, last ditch effort, without towing you, last call battery.
If you just want a new battery that will last, go with anything from Wallmart, Costco, any auto part store.
Old 10-03-2016, 09:44 PM   #11
makesdrivingfunagain
Isn't that covered under warranty still?
If you don't care about weight than there are more options to choose from. I went with a Braille and I replaced this after having the car for 2.5 years. I have the 15lb battery but it took some modifications to mount this battery. This is my daily driver and no issues so far in socal. You could probably find a high quality replacement battery from tirerack. Anyways, hope this helps
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
makesdrivingfunagain is offline   Reply With Quote
Old 10-04-2016, 02:28 PM   #12
JazzleSAURUS
I grabbed an ATV battery tray, and J hooks that were threaded all the way down to do this on a friends car.
I will likely be using the JDM STi battery tie down with a PC680 in my BRZ when the stock one fails.
Old 10-08-2016, 04:16 PM   #13
JGalp
i actually heard that triple A had some pretty good batteries. if not i think i will go with red top or just the costco one.
Old 10-08-2016, 08:03 PM   #14
guybo
Huge E85 fan!
guybo's Avatar
Whatever you do, don't let WalMart work on your car. I have seen some real sketchy stuff after people have gone to wally world for a NeverStart battery. You have to double check the work you get there because they are high volume, low quality and they will damage your car when they hurry through the service. They forget to put the battery hold down brackets on, don't seat the terminals well enough etc.
The Following User Says Thank You to guybo For This Useful Post:
Imperius (02-11-2017)
10 months old - battery dead this am. Auto off headlights? Large Issues | Warranty | Recalls / TSB 10 05-28-2016 10:12 PM
Catch Can & Lightweight Battery Solution by JDL Auto Design JDLAutoDesign Engine, Exhaust, Transmission 70 01-21-2016 07:27 PM
JDL Auto Design VTA Catch Can / Mini Battery Kit Jesse@JDLAutodesign Forced Induction 69 03-29-2014 07:22 PM
Auto Body Recommendations in the Acton area? Storm New England 0 03-25-2014 07:56 PM
Auto body repair shop recommendations in Broward/Palm beach? Mattitude Southeast 3 12-04-2012 05:54 PM
