Old 02-05-2019, 09:28 PM   #1
Cobaltbloo
Drives: 2016 scion FR-S
door ajar warning light
Hi guy's I am having a problem with my 2016 scion-frs. Something is draining my battery. I think it is the door ajar warning light. It is on all the time. I bought this pre-owned so I am not totally familiar with the car yet. But I am quite sure that this light is not supposed to on 24-7. It is something a dealership will have to fix im assuming..any help would be greatly appreciated.
Cobaltbloo is offline   Reply With Quote
Old 02-05-2019, 09:35 PM   #2
Is the light you speak of just a little symbol on the dash that lights up?
(I have a 2013 and it doesn't have that feature.)
If it's ON all the time, maybe the sensor in the door is stuck -
Anyway, I doubt that is what's draining your battery. I'd suggest you have the battery "load tested" and the alternator tested.
Old 02-05-2019, 09:45 PM   #3
It would appear you are not alone
http://www.ft86club.com/forums/showthread.php?p=2388768
http://www.ft86club.com/forums/showthread.php?p=1106989
Old 02-05-2019, 09:45 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Check the switches in the doors and trunk lid.
Old 02-06-2019, 09:00 AM   #5
Grady
Grady's Avatar
Just bought it? Take it back to where you purchased it.
Under warranty or just out? Take it to the dealer the will at times fix things just out of warranty.
Nether apply? Take lamp out so you don't drain the battery before you get it fixed.
Old 01-12-2020, 02:47 PM   #6
Magyarman
Magyarman's Avatar
Drives: 2016 FR-S series 2.0 , 2002avalon
Battery dead. New battery. The door ajar light would not go out. Sprayed teflon lube in door latches------all good now. It was the passenger door,that doesn't get any use.
Magyarman is offline   Reply With Quote
Old 01-12-2020, 03:15 PM   #7
Latches? The door state switch is that button in the frame. Window indexing and warning light are both functions of that input. State switch for the trunk is in the latch.
Magyarman (01-12-2020)
Old 01-12-2020, 04:15 PM   #8
Magyarman
Magyarman's Avatar
I sprayed the doors and the trunk latches,must have been the trunk switch?
Old 01-12-2020, 07:04 PM   #9
lehetséges
Underglow/footwell light controlled by door without using dome light or door switch pcguru2000 DIY (Do-It-Yourself) Guides 5 06-17-2018 12:09 PM
Warning Light? albeezy Issues | Warranty | Recalls / TSB 49 12-22-2016 09:01 PM
Door Ajar won't go off - HELP meow_mix Issues | Warranty | Recalls / TSB 19 10-21-2015 08:51 PM
Door Ajar Light will not turn off Aznek Issues | Warranty | Recalls / TSB 15 02-02-2015 10:40 AM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 05:20 PM
