#15 |
Drive From Home
Drives: BRZ STI Performance
#16 |
Drives: 2019 Mazda Miata RF
It does, but as a warning to anyone using it this way, the shifting is backwards. Look at the + and - near the selector. Every race car I've ever worked on was 180° from that, and my first attempt at using it resulted in a surprising down shift, instead of up, LOL. It was also the last time.
| The Following User Says Thank You to Gunman For This Useful Post: | Leonardo (08-09-2018) |
#17 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
All Toyota cars are backwards like this for whatever reason. |
#18 |
Drives: 2014 Scion FRS (Asphalt)
Could just buy a longer shift knob.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#19 |
The Fail Boat
Drives: CWP S.B.
#20 |
There ya go -
humfrz |
#21 | |
Drives: 2017 Brz
btw, check out sickspeed products on ebay, I have the adaptor( kind of like the manuals lift for reverse part) and a pearl shiftknob. I used the adaptor under the shift boot for a clean OEM look, but if you use it above the boot, its like an extension. |
#22 |
The Fail Boat
Drives: CWP S.B.
#23 |
| The Following User Says Thank You to Gunman For This Useful Post: | pinoy_dorifto (08-11-2018) |
#24 |
Yeah, when driving hard I use the paddles only. But just cruising around in a scenario manual works better (like rolling hills, traffic where I'm looking to pass, etc) I tend to use the shifter. And muscle memory from racing games and other cars I have driven is just too much lol
#25 | |
Drives: 2014 BRZ Limited A/T
Exactly the same! Sent from my iPhone using Tapatalk |
#26 |
Also you will need an adapter for the boot retainer, otherwise you'll have the exposed metal
#27 | |
Drives: 2017 Brz
| 18x9.5 stock height stock struts | etherealfall | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-11-2017 05:44 AM |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
| Coilover options capable of slightly increasing ride height. | Mechazawa | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-31-2014 01:23 PM |
| Post Your Stock Height 86! | VakaGT | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 03-19-2014 07:09 AM |
| BRZ vs 86 stock ride height | Moe | AFRICA | 2 | 11-21-2013 08:35 AM |
