| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Sold 16 FRS, 22 Neptune 86 on order
Finally upgraded from stock tires to 225 MPS4S!
Loving my decision so far, but I want to get some spacers for a little more umph. Does anyone have a picture of 225 tires with spacers? Really appreciated, thank you!
#2 |
Drives: 2022' GR86 Premium 6MT
225 Wheels? 225 is a tire size.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#3 |
Drives: 2014 GT86
If it's flush looks you are after, then how much they are spaced outside might be changed by both offset and spacers. Specify what offset/size wheels you have and how much further spaced out you want to find out looks of.
#4 |
Country Boy 4 Life
http://www.ft86club.com/forums/showt...t=59838&page=2
17x7 +48 OEM wheels use a 20-25mm front spacer and a 25-30mm rear spacer to be flush. The term "Flush" is subjective. What some consider flush, others would say pokes a little. You will have to make up your mind what "flush" is.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Kushkaki (03-11-2018) |
#5 |
Drives: 2015 FR-S
225/45/17 (17x7.5) +45 with 20mm spacer front / 25mm spacer rear front camber 0 / rear camber -1.7
| The Following 3 Users Say Thank You to Impureclient For This Useful Post: |
#6 |
Drives: 2014 Scion FRS (Asphalt)
Please don't put 20-30mm spacers on your car. That's a whole lot of weight just to look "flush"
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#7 |
Drives: 13 FRS
#8 |
At least you can put more rubber on it. But yeah, for aesthetics go ahead.
#9 |
A spacer will add under 2lb to each corner and its very close to the axis of spin so you won't notice anything..
| The Following User Says Thank You to PuslarBrrrz For This Useful Post: | Kushkaki (03-11-2018) |
#10 |
Drives: 2014 GT86
Actually one may notice change like heavier steering due changed scrub radius. Or if this had been FWD car, increased torque steer.
| The Following User Says Thank You to churchx For This Useful Post: | Kushkaki (03-11-2018) |
#11 |
Drives: 2015 Subaru BRZ Limited ISM
If you look up the specs the 225/45R17 PS4S are pretty heavy compared to stock. Just in tire alone he's adding a bit over 6lbs in weight to each corner. Add in spacers and you're really going in the other direction as far as adding performance....if you care for those sort of small improvements.
#12 |
Drives: Subaru BRZ
Are you?
1. Planning to race your car? 2. Planning on setting a land speed record? 3. Planning to set new race track lap times? If the answers are 'no' to the above then I think making your car look good in your eyes does no harm. Adding a small amount of weight will not dent your car's performance. Tyres, wheels, brake disk weights will vary as there are tolerances that need to be remembered. My first mod was dropping the car and adding 20mm spacers up front, 25mm at the back. I love the look.. Last edited by JD001; 03-11-2018 at 04:47 PM. |
| The Following User Says Thank You to JD001 For This Useful Post: | Kushkaki (03-11-2018) |
#13 | |
Drives: FRS 10-series
Stock height 15mm/20mm or 20/25 spacer F/R would be reasonable, 20/25 might have some poke. Keep in mind 15mm you will have to extend your lugs, the 20mm spacer can get away with an adapter style bolt on. |
| The Following User Says Thank You to rmr For This Useful Post: | Kushkaki (03-11-2018) |
#14 |
stock wheels and stock height, so thank you! I may go 20/25 F/R...
| Which upgraded tires for the BRZ? | pfaffendorn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 09-01-2016 09:38 AM |
| Upgraded Tires Happened Sooner Than Expected | wakawaka | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 02-29-2016 05:58 AM |
| Some thoughts after upgraded tires | Drakelee117 | BRZ First-Gen (2012+) — General Topics | 24 | 02-11-2015 03:21 AM |
| Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires | themajesticone | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-04-2014 03:49 PM |
| Retaining driving dynamic with upgraded tires? - frs | nixeighty6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 12-22-2011 02:44 AM |
