Old 08-17-2017, 04:24 PM   #29
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Yep, your story will need some work:
San Antonio, Texas, August, during the heat wave of 20XX, at least 112 degrees F.
One car, unventilated garage with uncured, rough concrete floor.
Wrenches were from K-Mart, with pieces missing; screwdrivers from Target, with broken handles.
Water was "gray" water, the wife had bottled up to use to water the plants.
There, that ought to keep your story moving along .......
If you actually drink the water more than the story will be moving along ... and swiftly.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 08-17-2017, 04:34 PM   #30
Originally Posted by TEWwild View Post
Air Force
Thanks for serving our country .........
Ok, enough chit chat, ladies. Add yourself to the duty roster.
Old 08-17-2017, 05:01 PM   #31
Ladies my ass, back in the day, this army soldier could whip, 4 sailors or 3 airman or 2 marines ......
Ultramaroon (08-17-2017)
Old 08-17-2017, 05:15 PM   #32
Icecreamtruk
Drives: Track preped NA FRS
Cool story, really good doc and glad you pulled it off. Nothing like being able to fix something seemingly too hard by yourself.
By the way, for those asking about oil consumption, mine uses around 1qtz every 2 month more or less, which is usually 3 to 6 track days. And for those suggesting to change oil before/after track, what do you think my pockets are made of? I cant change oil twice a week cant I?
Icecreamtruk is offline   Reply With Quote
Old 08-17-2017, 10:14 PM   #33
Regular army? Oh, please.
Old 08-17-2017, 10:42 PM   #34
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
Well the saga continues...went to the track as planned. Took it easy for the first session, came in reviewed data, saw no issues. Shot the shit for a couple hours, went back out, 3 laps in and something broke.... Consensus there is most likely a rod bolt let go, apparently you're not supposed to reuse them.... So here I sit back in the garage (this time they let me borrow a suburban and trailer). Pulling the motor tonight to see what broke, don't have to be at work until tomorrow night..... If I don't respond to comments, please understand I'm going to be busy for awhile....
TEWwild is offline   Reply With Quote
The Following User Says Thank You to TEWwild For This Useful Post:
Tcoat (08-18-2017)
Old 08-17-2017, 11:36 PM   #35
Shiiiiiiiit! Too late but study the parts breakdowns carefully. The big black dot is the key.
https://demos.starbase7.net/t3Portal...00T4V07IX.html
TEWwild (08-18-2017)
Old 08-18-2017, 01:59 AM   #36
Yep......Infantry
Old 08-18-2017, 02:13 AM   #37
Well, that's too damn bad .....
However, it's all part of the learning process.
The first large engine I overhauled, at about age 14, was a gas, inline 6, Oliver tractor engine.
When I put the rod caps with new bearings back on, I tightened them down good-n-tight. The engine wouldn't turn over (hand cranked engine).
The fellow at the parts store made me aware of shims that are needed between the rod caps and the rods. Yep, gave me a handful of shims and a length of the red, plastic string stuff and a gauge to determine how much the rod bearing was being squished when tightened down.
OK, my father was not happy with me, because he thought it was going to be a simple, relatively inexpensive valve job ........ NOT a rebuild of the lower end .... so, I got carried away ......
Well, TEWwild, at least the second tear down and rebuild should go faster.....
Old 08-18-2017, 04:02 AM   #38
TEWwild
TEWwild's Avatar
here we go again
Found the culprit, no broken bolts.... #3 rod cap cooked
Old 08-18-2017, 04:03 AM   #39
TEWwild
TEWwild's Avatar
#3 Rod cap removed, 2 halves of the bearing seem to have overlapped
Old 08-18-2017, 04:10 AM   #40
TEWwild
TEWwild's Avatar
Crank Journal.... Now I have a question here. It is my understanding the bearing material is softer than the journal and will go before damaging the journal. Is it possible the ridges are all bearing material and can be removed to reveal an undamaged journal. I wiped some with a rag and there seems to be a nice polished surface beneath. I understand if the rod contacted the journal there may be damage but I did shut her down pretty quick this time... Any thoughts
Old 08-18-2017, 10:54 AM   #41
If you managed to cut it before the journal got mangled too badly you may very well be able to save it.
Just spit balling here and I didn't go back and read your write up to see what parts from what engine you actually used but you did mention that the new engine was from a car with fire damage. Is it possible that some of the parts of the new engine suffered heat damage? Unlike heat from when the engine is running a fire can create very isolated hot spots which could cause damage that isn't obvious with an examination. Such hot spots could explain the mystery "weld splatter" material you found in the valve seats. This could be way off base for your current issue but thought it was worth mentioning since other things could fail down the road.
Old 08-18-2017, 12:47 PM   #42
Unless you just get a kick out of rebuilding that engine, I suggest you take the crank into a machine shop and have them resurface that journal. If, after they clean it up, it measures to within specs, you should be good to go.
Tcoat (08-18-2017), TEWwild (08-18-2017)
AC compressor pulley not spinning when dis-engaged? Lynxis Issues | Warranty | Recalls / TSB 7 05-03-2017 05:16 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 11:39 PM
pulley not spinning and then spins loud noise Composite Engine, Exhaust, Transmission 19 12-11-2014 08:09 AM
Spinning at Buttonwillow (1CW) ddeflyer Tracking / Autocross / HPDE / Drifting 76 05-22-2014 09:24 PM
Wheel choices got my head spinning!! Trmx2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 11-25-2013 10:34 AM
