Old 07-09-2017, 02:47 PM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm struggling with the thread title.. should read 'turn signals issues, need direction.'
The Following User Says Thank You to JD001 For This Useful Post:
Spuds (07-10-2017)
Old 07-09-2017, 04:34 PM   #16
Yep, that would be better.
Actually, they have direction ...... they are just sick .....
JD001 (07-09-2017)
Old 07-09-2017, 08:42 PM   #17
stevesnj
stevesnj's Avatar
YActually, they have direction ...... they are just sick
Like this guy...
My 2016 Build thread
Old 07-09-2017, 10:26 PM   #18
Originally Posted by stevesnj View Post
Like this guy...
Hey, ...... the shelf elf is watching you ......
Old 07-10-2017, 12:53 AM   #19
bass_114
bass_114's Avatar
Drives: wrb brz
my turn signal relay went out this winter, the turn signal on the passenger side permanently stayed on solid even after turning the car off. swapped out relay and worked again. Before i swapped out the relay I turned the hazards on/off repeatedly and and randomly it would "unlock" the signals and would work shortly, maybe try this if you don't have an extra relay handy.
bass_114 is offline   Reply With Quote
Turn signals don't always automatically turn off one2onejackpot Issues | Warranty | Recalls / TSB 6 04-18-2016 08:35 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 11:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 07:47 PM
OLM switchback turn signals issue bakilman Cosmetic Modification (Interior/Exterior/Lighting) 8 01-20-2015 01:21 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-12-2012 12:23 AM
