Old 08-04-2014, 07:02 PM   #1
bakilman
bakilman's Avatar
Drives: White FR-S
OLM switchback turn signals issue
I'm noticing with these turn signal LED bulbs that when I turn either side turn signal, the opposite side bulb will flash off for about a second and then light back up white.
Is anyone else experiencing this with these, or any other brand's, bulbs and if so what have you done to fix it?
Thank you
bakilman is offline   Reply With Quote
Old 08-11-2014, 06:59 PM   #2
bakilman
bakilman's Avatar
Drives: White FR-S
For anyone who may have seen this, I went with a different brand of LED switchbacks and don't appear to be having a problem anymore.
Old 01-19-2015, 08:02 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I had an issue similar to that. When one bulb was blinking, the other would strobe like crazy even after the blinker wasn't one. What brand did you go with?
Old 01-19-2015, 08:10 PM   #4
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Try to swap the bulbs for stock see if it still happens or try to swap out your flasher relay
Old 01-20-2015, 12:14 AM   #5
weederr33
weederr33's Avatar
The stock bulbs work fine.
Old 01-20-2015, 11:15 AM   #6
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Do you have a led relay?
Old 01-20-2015, 11:43 AM   #7
KI_ZN6
KI_ZN6's Avatar
It sounds like a circuit problem with the switchback LEDs. Our customers have been using our A-tech Switchback LEDs and they are quite happy with them. If you reinstalled the factory bulbs and the problem is gone, then there is likely an issue associated with the LEDs.
Another thing to look for is the flasher module. If you have not upgraded this part, then you will experience flash-blinking turn signal LEDs. If you have installed a new flasher module with the LEDs, disconnect it and ensure that all the PINs are properly aligned and have full contact with the connector.
KI_ZN6 is offline   Reply With Quote
Old 01-20-2015, 12:15 PM   #8
weederr33
weederr33's Avatar
I have an LED flasher module as I have the LED rear blinkers. So it was probably the switchbacks I had before. Any suggestions to some good switchbacks would be nice.
Old 01-20-2015, 12:21 PM   #9
KI_ZN6
KI_ZN6's Avatar
We recommend our A-tech Switchback LEDs and you will find them listed under Scion FR-S lighting products (front turn signal LEDs).
Feel free to send us a PM or email if you need assistance or more information.
Diode Dynamics Switchback Turn Signals LED 2isballer Cosmetic Modification (Interior/Exterior/Lighting) 2 03-02-2014 01:46 PM
Switchback LED turn signals (white/amber) + Relay FRSpdDmn Exterior Parts (Aero, Lighting, Etc.) 11 08-02-2013 11:23 AM
Switchback led turn signals installation Scionshaun Cosmetic Modification (Interior/Exterior/Lighting) 1 05-24-2013 06:31 PM
Request - 5000k LED Switchback Turn Signals raul Cosmetic Modification (Interior/Exterior/Lighting) 8 03-07-2013 06:50 PM
Are Switchback Turn Signals Legal? i_4got CANADA 7 11-03-2012 05:47 PM
