Old 04-10-2017, 06:00 PM   #29
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Mr Nerd View Post
I have all of these, with the exception of a rear diffuser.
Sent from my LGLS991 using Tapatalk
I don't know that it helps with stability much, but a proper diffuser will change from lift to a touch of downforce in the back. I'm​ confident it would help at least a little.
Old 04-10-2017, 06:06 PM   #30
Mr Nerd
Mr Nerd's Avatar
I have been anxious to get one but I am the type of person who does way too much research for such simple things.
To you have one? Do you have a recommendation?
Mr Nerd is offline   Reply With Quote
Old 04-10-2017, 06:13 PM   #31
JDM4E
Drives: Honda Accord Euro
Originally Posted by ls1ac View Post
I was referring to the OP that had modded his car and was having problems in Europe with the car darting right and left in the wind.
The car was dealer stock, I have never said I modded anything. Our specs include OEM underbody panels and that MY2017 rear spoiler. It is really weird.
EDIT:
I have found this post with an interesting thought: http://www.ft86club.com/forums/showp...0&postcount=17
P.S.: I have a theory that not that much people experiencing this just because not much people travel at those high speeds? The faster you go the worse this is, so perhaps not much high speed driving with combination with wind makes this topic a bit underground?
EDIT2:
I just found on UK forum people noticing this too, with no solution. We are not alone Check this out:
http://www.gt86ownersclub.co.uk/foru...topic3573.html
JDM4E is offline   Reply With Quote
The Following User Says Thank You to JDM4E For This Useful Post:
7 skulls (04-10-2017)
Old 04-10-2017, 06:51 PM   #32
cjd
cjd's Avatar
Drives: 2017 BRZ
Velox, Driveway labs... Others out there with less shared data. Not all exhausts always fit, etc. so you'll have to dig in a little still, I think.
Old 04-10-2017, 10:06 PM   #33
ls1ac
ls1ac's Avatar
sorry, I stand corrected.
I did not realize that yours came stock with different options.
again, not sure the two posts experienced what you were experiencing what you had happen at high speed. did you notice the instability at high way speeds? you seemed to say it was a high speed related problem.
I was only trying to help with a possible place to start looking, based on personal experience. we are all aware that all cars experience affects of strong crosswinds it is really a matter of how much.
Old 04-11-2017, 12:51 PM   #34
Gunman
Drives: 2019 Mazda Miata RF
Being in Europe isn't going to make a difference. I suffer from all of the same problems in America. 😞 And I have opted for all of the solutions in this post. So whether I am the OP or not, what is your point?
Side splitters should help with cross wind, as they are intended to work when the car is in yaw. I noticed less buffeting around tractor trailers since I installed mine. Keeping the air from getting under the car is key.
Old 05-09-2017, 04:50 PM   #35
JDM4E
I have just found another thread about this
http://www.ft86club.com/forums/showthread.php?t=20857
Still wondering what the hell is going on and how to make this car stable...
Old 05-09-2017, 07:15 PM   #36
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Still on the stock low-rolling resistance made-for-fuel-economy tires? That's what it was for me....proper performance tires cured the high speed wandering it liked to do.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-09-2017, 07:37 PM   #37
OND
OND's Avatar
Drives: 2023 BRZ
I'd second the alignment suggestion. Our cars are already pretty good aerodynamically, with low Cd, small surface area and a functional rear spoiler.
If you want a 100mph highway cruiser, this car is probably not the best starting point (light, short, stiff susp.), but I'm pretty sure a good amount of toe in would make it much more stable on the highway, at the expense of low speed maneuverability.
OND is offline   Reply With Quote
Old 05-10-2017, 04:28 AM   #38
JDM4E
In the thread I mentioned there is an another theory and that is soft bushings...
JMon85 (05-10-2017)
Stability Control intervention at very low speed smbstyle Issues | Warranty | Recalls / TSB 10 07-15-2016 03:11 PM
High winds + large water tank = Manji Off-Topic Lounge [WARNING: NO POLITICS] 10 10-06-2015 01:33 AM
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 03:59 PM
Light weight and high winds in a Subaru alluringreality BRZ First-Gen (2012+) — General Topics 49 03-01-2014 07:04 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 01:37 AM
