Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-28-2012, 05:32 AM | #1 |
Pegasus White
Drives: 86
Floating feeling
For a while now I feel like I am floating alot through corners and it doesn't feel as precise as it once did or I am too used to how it feels and its not stiff enough.
Even when I am driving 60km(normal road speed limit) i can feel the car move about in my lane and always correcting where it is moving around. What would be the cause of this? I've have done 8000kms on the car and it is completely stock heaps of rubber left. I did have a puncture in my rear right tyre this as been fixed and it still feels floaty. I am not sure if I need new rubber or new suspension. What do you recommend?
Driving: Pegasus White Manual GTS 86.
10-28-2012, 05:38 AM | #2 |
Drives: '13 86
Did you check the air in all four tires?
10-28-2012, 05:44 AM | #3 |
Pegasus White
Drives: 86
No I personally haven't but when my tyre was fixed they checked all pressures but I will check them next time I get fuel (Tomorrow).
10-29-2012, 08:07 AM | #4 |
Pegasus White
Drives: 86
so tyre pressures where fine all above 40 psi...
Which i was a little wierd since the plack on the door says 35psi... what should it be?
10-29-2012, 08:20 AM | #5 |
Drives: anyone seen my steering wheel?
What do you mean by floating feeling?
How large are the movements? and how are you correcting them? With a well tuned car suspension you will get some movement in the corners, part of this is perceptual, and part is real. The Perceptual part is that most turns in the real world have a bit of variation to them, rarely will you have any that run a perfect arc. You are also sitting much closer to the road and as you gain awareness of the vehicle you will notice movement that you didn't in say a pick-up truck (even if the movements are the same). Real movements result from a couple of factors. One of these is how you drive, in these cars even minor differences in power application can result in some movement, as well as how smoothly you turn in and exit the turn. Another thing that can cause real movement of the vehicle is the road surface; bumps, divots, and undulations all cause a vehicle to move. You are also at the mileage (kilometerage?) where stuff is broken in allowing it to move easier. Of course it could also be plenty of things out of whack as well, like your alignment, differing tire pressures, loose ball joints or rod ends, loose suspension pieces, loose nut behind the wheel, etc... |
The Following User Says Thank You to DEnd For This Useful Post: | DriftEightSix (10-29-2012) |
10-29-2012, 08:22 AM | #6 |
#TrackAddicts
Drives: The Dipped Car
cold around 34-35, warm 38-40, starts to fall off around 44
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography |
The Following User Says Thank You to BadCompany235 For This Useful Post: | DriftEightSix (10-29-2012) |
10-29-2012, 08:34 AM | #7 | |
Pegasus White
Drives: 86
Happy to admit I am not the best of drivers and i might take the wrong line more often then not, but when turning i always aim for a smooth wheel motion not jaring motions. Alignments should be okay after the repairs tyre. Might have to get under the car and poke around for lose things as I did notice it after they "replaced my trans oil". What is around that area that could cause this effect? Might also book it in for its first service.
10-29-2012, 08:36 AM | #8 |
Pegasus White
Drives: 86
I guess i did drive it for about 10 mins before getting fuel so 40 for warm sounds okay to me.
10-29-2012, 08:49 AM | #9 | |
10-29-2012, 09:26 AM | #10 |
The Answer
Drives: Mazda 2
The car is definitly very sensitive as far as steering goes, any little movement will results in a change of direction. If you get an alignment with more toe-in I think it might help as it makes the car more prone to head up straight ahead. Somebody might want to chime in about it...
10-29-2012, 11:46 AM | #11 | |
The place to start is tread wear, and alignment, and a good inspection of all the suspension and steering mounting points. |
10-29-2012, 02:39 PM | #12 | |
Drives: Black 2013 FRS
10-29-2012, 02:44 PM | #13 | |
i'm sorry, what?
Drives: Canada
you wont have an issue with bump steering affecting the right and left wheels differently thus having every single bump force your car to change direction at different rates.
10-29-2012, 05:27 PM | #14 |
IMO everyone should get the OEM camber bolts and have the car aligned once they get the car. Makes a huge difference and those bolts are dirt cheap. I don't trust factory alignments anyway.
I'm not convinced that's the problem here though...I think the FR-S is just really soft up front and the chassis moves around a bit. Super soft springs and squishy bushings. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Moshpit37 (01-27-2013) |
Similar Threads | ||||
Oh What A Feeling - Toyota Jump lives on! | bestwheelbase | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 11-20-2012 02:02 AM |
driving in 1st weak/stuttering feeling | deedz | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 07-25-2012 06:33 PM |
Like my FR-S, but still like the feeling of my Celica GT-S | brieweb | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 07-04-2012 05:16 PM |
Tomzilla's "That feeling when your car is far cooler than you" BRZ thread. | Tomzilla | Member's Car Journals | 1 | 06-19-2012 12:10 PM |
Anyone feeling amped up? | NemesisPrime909 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 08-04-2011 07:49 PM |
