Old 03-22-2017, 05:11 PM   #29
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Originally Posted by kask2_6.0 View Post
Any possibility of a lower priced FRP version?
Excellent question. I asked Joel. He said, "At this time, I am only doing full carbon and dont have plans to do a fiberglass version". He went on to say if you wanted to paint, he would take $100 off and not clear it.
Hope that helps. This dude is really only interested in making stupid light car parts. He just recently made a GTR rear boot lid that looks phenomenal and weighs nothing.
xkalelx is offline   Reply With Quote
The Following User Says Thank You to xkalelx For This Useful Post:
kask2_6.0 (03-23-2017)
Old 03-23-2017, 09:12 AM   #30
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
that's awesome.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
xkalelx (03-23-2017)
Old 03-29-2017, 03:55 PM   #31
MPHfab
Drives: '14 frs getting lighter and lighter
Originally Posted by xkalelx View Post
Kind of annoying Joel isnt on the forums.
Finally lol I'm here 👋🏻 I'm working on some parts at the moment but I'm gonna try and go through here later and answer some of the other specific questions and measurements. as far as the edelbrock goes I think it should clear fine with as far forward as the vent is. I'll post pics as soon as I can figure out how to reduce them down from my iPhone so it will let them post.
MPHfab is offline   Reply With Quote
The Following 4 Users Say Thank You to MPHfab For This Useful Post:
ajaxthebetter (03-29-2017), shiumai (03-30-2017), whataboutbob (11-13-2020), why? (03-30-2017)
Old 03-30-2017, 10:32 PM   #32
MPHfab
Confirmed fitment with the edelbrock supercharger today. It just barely touched the intake tube but was able to close with normal pressure and didn't touch until all the way latched. We also noticed the mounting brackets for his airbox were slotted and could have been moved down about an 1/8" and wouldn't have touched at that point. https://www.facebook.com/MPHfabricat...29530573844478
The Following 2 Users Say Thank You to MPHfab For This Useful Post:
Paulo86 (02-06-2018), whataboutbob (11-13-2020)
Old 03-30-2017, 10:38 PM   #33
MPHfab
Originally Posted by Gunman View Post
FYI, that radiator exit duct would work a lot better, if there was a duct from the back side of the radiator, up to the hood exit.
100% agree but with so many various setups it's kinda hard to make ducting that will work with everything but I've toyed around with the idea of making something to work with the factory rad, fans and support and then could be trimmed to fit various intakes or other obstructions. Would love to incorporate a v mount setup with this hood but that would likely be more of a one off project.
Old 03-30-2017, 10:50 PM   #34
MPHfab
Originally Posted by Kiske View Post
@xkalelx is this a 2-piece hood that has been bonded together? (Inside/structure skin and outside/exterior skin.)
It doesn't have a full skeleton but there is a fully boxed perimeter skeleton that just goes around the edge. Because it is 100% carbon it is stiff enough that it does not require a full skeleton. Also because the perimeter skeleton is bonded all the way along the outside and inside edge completely boxing it in, the entire part becomes very rigid against twisting vs just having a full skeleton glued around the outside edge and spot glued around the center areas. This is a big part of reason the weight was able to be cut so low but still allow it to be a bolt on part with a normal latch, but it could also be made with a foam core skin only as a lift off hood.
The Following 3 Users Say Thank You to MPHfab For This Useful Post:
Kiske (03-31-2017), shiumai (04-03-2017), why? (04-02-2017)
Old 04-07-2017, 10:15 PM   #35
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by MPHfab View Post
Looks very nice & great to see how light it is.
Quick question. This cf hood latch to OEM or need aftermarket hood pins & latch?
Old 04-08-2017, 07:13 PM   #36
ogrowup
Drives: Asphalt build in progress
Is it installed yet? Have you taken it for a high speed run? I have a lightweight CF hood and it has about the same rigidity as a potato chip. Very scary at anything over 75mph. I want a vented hood because I have a boosted car and the engine bay is hot AF. Please tell us your experiences in driving the car at higher speeds.
ogrowup is offline   Reply With Quote
Old 04-20-2017, 09:34 PM   #37
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Any updates on testing, pics?
shiumai is offline   Reply With Quote
Old 04-21-2017, 12:30 PM   #38
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
@MPHfab Ehem. I would happy to accept one of these hoods to test fitment with the Full Blown Motorsports kit. Heh.
EDIT:
WAIT A SECOND. You are in Dayton? I could quite literally come visit if you honestly wanted to test the hood on my car for fitment.
blackfireball5 is offline   Reply With Quote
Old 04-21-2017, 12:39 PM   #39
MPHfab
It does have a latch and that's all I personally use but it is always recommended to run hood pins on any composite hood.
The Following User Says Thank You to MPHfab For This Useful Post:
ichitaka05 (04-21-2017)
Old 04-21-2017, 12:45 PM   #40
MPHfab
There is a video posted to the Facebook page https://www.facebook.com/MPHfabricat...9824436148425/ of a string test going 80 showing it perfectly stable and I've had it to 95mph briefly off camera and it's just as stable. The carbon perimeter frame and the shape added with the vent are what keep it rigid as a whole while keeping it light and being 100% carbon helps the skin stay somewhat flexible without cracking or breaking but be stiff enough to not flop around from the air pressure.
shiumai (04-21-2017), Suparu (07-16-2019)
Old 04-21-2017, 01:00 PM   #41
MPHfab
The airflow meter placed in the front vent showed similar flow readings in cfm as the naca ducts at the same speeds did. With the opening of the vent at roughly 50"sq and the NACA ducts having 3" round outlets (7"sq each) so there is 72% more air being sucked out of the front than there is being pushed into the NACA ducts combined. There is a video on the Facebook page of a string test that shows how early on the vacuum effect starts to pull air through the vent (around 15-20mph) and it consistently gets stronger as speed increases. https://www.facebook.com/MPHfabricat...9824436148425/
Old 04-21-2017, 05:57 PM   #42
shiumai
shiumai's Avatar
@MPHfab - Joel, what do you think the effect would be of removing the rear rubber OEM hood seal? On a stock hood, the positive pressure in front of the windshield without the seal might cause stagnation in the engine compartment and prevent airflow through the radiator. But, in the case of your hood, would removing the seal compliment the two NACA ducts and increase/improve the amount of air/heat going out the front vent?
APR Carbon Fiber Radiator Cooling Plate & Brake Ducts LANI86 Exterior Parts (Aero, Lighting, Etc.) 3 12-21-2016 07:19 PM
Looking for R35/GT-R Aero data... on the NACA ducts Kiske Other Vehicles & General Automotive Discussions 0 03-03-2016 09:34 PM
Hood Venting, NACA Ducts Lunatic Scion FR-S / Toyota 86 GT86 General Forum 70 02-08-2015 12:10 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 02:39 AM
APR Performance Carbon Fiber Brake ducts! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2013 03:56 PM
