Old 09-20-2016, 10:18 PM   #15
Originally Posted by BRZ'13 View Post
ok this is certainly the issue. exact description in the second link. lowered + sticky tires + 300whp will do it.
Thank you!
Excellent it is likely the easier fix of the two. Let us know if that fixes it so we can pass it on to the next guy.
Now I can go troll a few posts in good conscience.
Old 09-21-2016, 12:53 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
only other mod back there is SPC control arms at about 2.3 degrees camber
i cant see it being the coils since its only at low speeds. maybe contributing to the cause?
Before you blow money on axles I'd spend five minutes disconnecting the rear sway bar (just remove one endlink) and going for a test drive.
I was going crazy searching for a clunk as well, thought it was my custom spring perches but it turns out my LCA's (not SPC) didn't play well with my stock rear bar and endlinks especially after being lowered, the way everything was toleranced created a clunk.
Might not be the answer but it's a cheap test.
ineedyourdiddly
Rear suspension clunking noise. Help ): dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 09-15-2016 04:09 AM
Loud clunking underneath driver's side area: suspension, chassis, or wheel related? loading_please_wait Issues | Warranty | Recalls / TSB 4 06-18-2015 04:13 PM
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 05:11 PM
Clunking sound coming from suspension Maverickgear Issues | Warranty | Recalls / TSB 9 07-11-2014 03:41 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 11:00 PM
