Old 07-20-2016, 12:03 AM   #15
Mattstermh
Drives: '13 FR-S A/T - Stock
It could be the transfer case going out.
Think it's the bearings? The noise is extremely hard to notice, but I pick up on it every time because I'm the one obsessed with the car.
Mattstermh is offline   Reply With Quote
Old 07-20-2016, 12:07 AM   #16
No no... I was hoping to set up a joke with humfrz. Guess it backfired.
I'm sure it's fine, really. Sooorrrryyy...
edit: Wheel bearings don't make a high-pitched noise. They more growl when they're gone. If you've ever driven on cupped tires it sounds very similar.
Cole (07-26-2016)
Old 07-20-2016, 12:15 AM   #17
Do you think you can record it, or is it too subtle?
Old 07-20-2016, 12:29 AM   #18
Mattstermh
Definitely way too subtle. I won't worry for now. Thanks
Old 07-20-2016, 12:47 AM   #19
Or, the front differential ........
Cole (07-26-2016)
Old 07-20-2016, 01:02 AM   #20
Now, see what you did, there Ultramaroon ........
@Mattstermh like @Ultramaroon says, a bad wheel bearing will usually "growl" if they are bad. You can usually make a bad wheel bearing make noise by driving down the center of a road at around 30 mph and turn the wheel back and forth so the car moves from one side of the road to the other.
But my money is still on the front differential, most likely a left spider gear bushing. However, I'll ask @Ultramaroon elaborate on that.
Ultramaroon (07-20-2016)
Old 07-20-2016, 01:15 AM   #21
Oh, forget it. :|
Cole (07-26-2016), humfrz (07-20-2016)
Old 07-20-2016, 02:04 AM   #22
Quicksilverfrs
Drives: 2014 Firestorm FRS
Had the same exact issue on my Lexus IS300. Popped the hood open and it turns out that it was a bad serpentine belt. Do you notice the noise more when the A/C is on? If so it's definitely the serpentine belt or a loose tensioner.
Quicksilverfrs is offline   Reply With Quote
Old 07-21-2016, 12:32 PM   #23
Mattstermh
The problem is not there when the AC is on
Old 07-26-2016, 08:58 PM   #24
Cole
Not a troll
Cole's Avatar
ELLE OH FUCKING ELLE.
Thanks for making spit my first beer of the week all over my laptop, instead of enjoying it like I should be.
Asshole
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Ultramaroon (07-26-2016)
Old 07-26-2016, 09:50 PM   #25
Originally Posted by Cole View Post
Asshole
That went sideways fast. I felt awful when OP took me seriously.
Cole (07-26-2016)
Old 07-26-2016, 11:11 PM   #26
Cole
Not a troll
Cole's Avatar
Plz tell me how to activate my transfer case. I don't see a button for it.
Old 07-26-2016, 11:24 PM   #27
USDM-only feature. You guys get heated mirrors.
Cole (07-27-2016)
Old 07-27-2016, 01:12 AM   #28
Your car only has half of one ....... and it's activated by default .......
Cole (07-27-2016)
gas pedal vibration nfaj BRZ First-Gen (2012+) — General Topics 6 09-28-2014 04:25 PM
Ac vibration and aound when starting car and lwtting it just idle? Frs32907 Issues | Warranty | Recalls / TSB 6 07-16-2014 03:53 PM
2600rpm vibration stueck9356 Issues | Warranty | Recalls / TSB 3 03-06-2014 01:06 PM
uneven engine vibration at idle whtchocla7e Issues | Warranty | Recalls / TSB 17 08-07-2013 10:21 PM
