Old 07-07-2016, 02:18 AM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Grinding noise when AC on
Hello,
When and only when the AC is on. I hear I grinding noise when I am driving and then shift to neutral. As I am braking the noise will come
There is no specific RPM range where the noise come, but it comes infrequently. Maybe it comes while I am driving. I don't hear it though, full exhaust changed.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 07-07-2016, 02:54 AM   #2
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
The power steering is electric, there is no fluid. Have you changed wheel/tire/alignment recently? Is your Power Steering Warning light on?
You need to take a video of the sound so we can get a better idea of what it is. Right now, it's difficult to tell what it may be.
- The Ancient BRZ Sacrament
by Zaku
Old 07-07-2016, 04:15 PM   #3
Yep, either a video and/or a more complete description of what you are feeling/hearing.
Old 07-07-2016, 04:43 PM   #4
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Originally Posted by Mikeez View Post
First and foremost, lol "foremost" I got few problems with the FR-S. The steering wheel is now stiffer than usual. I changed the fluid but still stiff.
Moving on, when and only when the AC is on. I hear I grinding noise when I am driving and then shift to neutral. As I am braking the noise will come
And also, I presume you used power steering fluid when you changed the fluid. If so, you need to figure out what fluid you did change (probably clutch or brake) and flush the affected system. Or things may break.
theadmiral976 is offline   Reply With Quote
The Following User Says Thank You to theadmiral976 For This Useful Post:
Guff (07-08-2016)
Old 07-08-2016, 01:06 AM   #5
Guff
Guff's Avatar
Drives: BRZ LZR
Let's hope it didn't go into the engine oil fill...
by Zaku
Old 07-08-2016, 01:50 AM   #6
ryoma
ryoma's Avatar
what could he have poured the PS fluid into? the engine oil cap says oil on it I believe and the brake MC is pretty obvious. maybe clutch? or maybe just the coolant overflow lol. hopefully he didn't pour it into the brake reservoir otherwise that is bad news if he drives the car and its sucked into the lines
Old 07-11-2016, 02:25 AM   #7
Mikeez
Engineering Student
xD forget the steering wheel. I will try to film the ac noise
Grinding noise in neutral WGMGR Issues | Warranty | Recalls / TSB 28 04-12-2018 03:22 AM
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 09:53 AM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 11:57 AM
Squeaking Noise From Steering Wheel tonytduc Scion FR-S / Toyota 86 GT86 General Forum 4 01-28-2013 08:58 PM
buzzing noise from steering wheel FR-S :DK Scion FR-S / Toyota 86 GT86 General Forum 1 10-07-2012 02:52 AM
