Old 08-06-2012, 08:54 AM   #1
Slant
.....V.....
Slant's Avatar
Drives: cars
Noise when turning steering wheel at low speed
This has been bothering me since the day I picked up the car. I searched and searched and couldn't find a single complaint about it so hopefully it's normal or I'm in the minority.
So, when moving at slow speeds, like going into a parking space or up a driveway, there is this faint noise when I turn the steering wheel quickly say more than a half revolution. Sounds kind of like a rubbing noise of some sort. Does this happen on yours?
Edit: Oops, forgot to mention, the noise comes from around the steering wheel / steering column area.
Slant is offline   Reply With Quote
Old 08-06-2012, 09:28 AM   #2
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
If this is coming from the rear of the car then it's the LSD. A small amount of noise is normal at very low speed turning from my understanding. I only have that noise in the morning after a cold start.
Hanzo is offline   Reply With Quote
Old 08-06-2012, 09:31 AM   #3
m0nty
m0nty's Avatar
Drives: 86 GT
Electric power steering does have a slight noise when being applied quickly at low speed.
The LSD noise will be tyre slip on the inside wheel that you'll almost kind of feel through the seat.
m0nty is offline   Reply With Quote
Old 08-06-2012, 10:22 AM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
Almost 100% sure you are hearing the power steering electric motor. There was a YouTube video where Subaru engineers discuss the unique chassis and they pointed out that in order to get the steering rack positioned right to allow the low flat engine they moved the electric power steering motor to the steering column on the cabin side of the firewall. There might be something in the manual saying a slight occasional whine from the steering column is normal.
Old 08-06-2012, 07:31 PM   #5
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
It's the Electric Power Steering module...it's completely normal, it's just the motor assisting you in turning the steering wheel.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 08-06-2012, 07:48 PM   #6
Slant
.....V.....
Slant's Avatar
Drives: cars
Thanks everyone for your responses. My previous MINI Coopers S had a distinct steering whine which sounded more "electric" or "robotic" if there's such a thing which was normal for its electric assisted steering. The 86's noise is more "mechanical" type of noise that's what got me worried.
Glad to hear it's normal. Cheers.
Old 11-06-2015, 04:31 AM   #7
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
I swapped to Final Drive 4.88 and now the car not passed 100miles
diff assembled very good and I hear no noise in straight line but in sharp turning at very low speed i hear bad noise , lap lap lap lap lap noise.
my car has LSD but i used addinol diff oil that has not LSD additive
any idea for removing the noise?
Toyota86.ir is offline   Reply With Quote
Old 11-06-2015, 08:53 AM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I have the exact same sound which I attributed to the electric power steering. I'm hearing it in the same situations you are. Nothing to worry about imo.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 12:56 AM
Steering wheel.. anyone else bothered by.. earthsscum Cosmetic Modification (Interior/Exterior/Lighting) 18 06-06-2012 12:00 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 10:43 AM
