Old 07-05-2016, 01:51 PM   #29
Ashikabi
Ashikabi's Avatar
Originally Posted by Twinz View Post
So the video I linked is me, in my car, launching near the top of the tach....with no blinking lights.
I'm not sure what exactly causes the lights to flash but since I posted in that other thread from a year ago I have had the light flash during autocross but I didn't notice any other affects. I do not pedal dance, just hold the button for 3 seconds. Maybe it's different on the track or with better tires etc. As far as I can tell from personal experience, the light just flashes sometimes during slides but doesn't intervene
Old 07-05-2016, 02:16 PM   #30
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Lol you tag me into this thread, bitch about old shit, then tell me to fuck off? You're far more mature than I could ever be
When it's off, it's off. There is no maneuver you can do that will make it activate.
Do you or do you NOT believe that the trac & VSC system can respond when it is 'deactivated' or 'disabled'?
THAT was the topic of the thread.
You clearly believed (incorrectly) that it would NOT respond when off.
Have you changed your opinion on that matter or not?
I merely pointed out facts, and used you as an example of a person who does not understand the system.
YOU started with the insults first NOT me.
justatroll is offline   Reply With Quote
Old 07-05-2016, 02:18 PM   #31
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Maybe there is a difference between the model years/ software?
The only twin I got out of shape a lot was a BRZ I co-drove at Dixie a few years ago. The car's owner had an alignment shop set the car up with toe-out on the rear and the throttle was almost unusable with the back end kicking out like the car had 800hp.
He got the alignment fixed between day 1 and day 2, and the car was great then. However, neither of us noticed any blinking lights in real time or on the over-the-shoulder video we reviewed afterwards.
Twinz is offline   Reply With Quote
Old 07-05-2016, 02:29 PM   #32
Ashikabi
Ashikabi's Avatar
I have yet to have it respond with anything more than a flashing light as started in the above post. At the time of the thread I was mentioned from, I had never experienced any affect of any kind once traction control was turned off. And you started the insults in post 18 on page 2
Old 07-05-2016, 02:29 PM   #33
justatroll
justatroll's Avatar
While remaining on topic: I have had the system disabled with the 3 second button press and had it come back on and spin the car in the snow/ice.
During the spin, the lights were blinking and when the car came to a stop the VSC & TC lights were OFF (meaning re-enabled)
This thread has others' experiences about this topic (and more examples of Ashikabi being a prick):
http://www.ft86club.com/forums/showthread.php?t=107910
BTW - on my car you CAN disable VSC&TC when moving at any speed, while others have questioned this.
Just a data point for noting differences.
Old 07-05-2016, 02:43 PM   #34
Ashikabi
Ashikabi's Avatar
It's very flattering how obsessed you are with my comments. Most people just let it go or forget about me etc... but you are something special. You are proof that my work on the internet is both noticed and will leave a legacy of butthurt across the world and one day, the stars. Thank you. Autographs are available for 7$. 5 and 10 dollar bills only, no change.
Old 07-05-2016, 03:26 PM   #35
Twinz
Twinz's Avatar
Mine can be disabled at any speed as well. Although when moving, nothing happens for a few seconds...then both lights come on. When stopped, the TCS light comes on the moment you press down and the other light comes on after a few seconds of holding it down.
Old 07-06-2016, 08:59 AM   #36
kevman_101
Drives: 2013 Scion FRS
Spinning the tires won`t light it up, Spinning out won`t light it up, but if you flick it aggressively or get bumps while turning and the inside rear wheel loses enough traction, it will dab the brakes to activate the rear diff like a limited slip... Only it would be better not to sometimes. The torsen works if both tires have grip, if one gets lifted, it works as an open diff. To counter this, the system applies brakes to the wheel with no grip to give the other wheel the power and also lights up the traction light on the dash. It can cause so weird problems I imagine at track speeds, and I think the better the tires, the more often it happens as it unloads the inside wheels even more. I get it to blink at 3000 rpm at 1/4 throttle on a street I turn on to everyday because of humps crossing the road.
I haven`t had a single problem while autocrossing with the 3 seconds button press, but they are 2nd gear courses only.
kevman_101 is offline   Reply With Quote
The Following 2 Users Say Thank You to kevman_101 For This Useful Post:
Ashikabi (07-06-2016), Twinz (07-06-2016)
Old 07-06-2016, 03:52 PM   #37
Norinradd
Drives: 2013 frs
Doesnt happen from A launch to often its more so when im sideways around a bumpy bend or in a drift when i flick the car
. I have noticed it happen with many others on youtube
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 07-06-2016, 03:56 PM   #38
Norinradd
Drives: 2013 frs
http://www.ft86club.com/forums/showp...1&postcount=82
I didn't notice an issue when I ran my car stock recently. ^
None of the other Twins I have driven over the years have shown this problem either. (Most of them were BRZ's, but not all)
I have seen drivers completly spin both FR-S's and BRZ's with no pedal dance.
I'm not arguing what level of intervention may or may not be happening with just the hold-button-down method, but the cars seem to respond to inputs without protest....even when those inputs are bad ideas that cause spins.
...and I don't remember any of the lights blinking at me when I held down the button long enough to get both lights on.
Your car stayed relatively straight that whole run. In relation to front and back wheels. If your tail was whipping out wveey corner like 45 +degrees i have a feeling shed have blinked at ya
Old 07-06-2016, 05:31 PM   #39
Twinz
Twinz's Avatar
This sounds like the most likely scenario. I actually had issues on the tail of the dragon with my STU 350Z unloading the inside tire enough to make the Quaife diff go open. (On some of the tighter, well-banked corners)
I totally get what Toyota/Subaru were addressing here. I may actually be thankful for it in some conditions. If/when it becomes a problem, I will look at alternatives that do not involve an elaborate routine, and disabling EBD. (I think I can remove the rear sway bar in CS)
If my car gets out 45 degrees, the run is already shot...and it's my own fault, before any electronic response the car might have.
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
ABS/Trac Slip Light (C1231/C1234) Rifle Issues | Warranty | Recalls / TSB 5 02-09-2016 07:46 PM
ABS and TRAC Light came on last night Sargy Issues | Warranty | Recalls / TSB 33 10-27-2015 05:33 AM
Car just got repaired - Is this how it's supposed to look? jarviz Scion FR-S / Toyota 86 GT86 General Forum 33 11-26-2014 06:27 PM
CEL + TRAC light... seven Issues | Warranty | Recalls / TSB 7 02-22-2013 11:52 PM
