Old 07-03-2016, 02:42 PM   #1
Norinradd
Drives: 2013 frs
Trac cntrl light supposed to blink when off?
Just wondering, traction control fully off. When i hold the trac button don for 3 seconds. The correct lights appear on the right hand side. But when i get spinning the light on the tach blinks. Is it supposed to do this? Or is trac control still engaging?
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 07-03-2016, 04:17 PM   #2
lazyluka
Drives: GT86
Still be active in the background unless you use the "Pedal Dance" or disconnect the ABS fuse (no ABS then).
Search forums for "Pedal Dance" and read up about it.
lazyluka is offline   Reply With Quote
Old 07-03-2016, 04:41 PM   #3
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Contrary to what some on this forum believe: The 3 second press does NOT completely disable the TCS & Stability control
justatroll is offline   Reply With Quote
Old 07-03-2016, 04:48 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
What? I'm pretty sure everyone agrees that it doesn't completely disable the traction and stability control, hence pedal dance.....
Old 07-03-2016, 05:06 PM   #5
Norinradd
Drives: 2013 frs
Yes im aware. Just wondering if i hold the button down for 3 seconds if the tach light is supposed to still blink when im spinning tires
Old 07-03-2016, 05:07 PM   #6
Norinradd
Drives: 2013 frs
If only the search button worked, search threads for "pedal dance" get 6+ pages of threads, none titled pedal dance. Lol
Old 07-03-2016, 05:10 PM   #7
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Even with traction off, electronic breaks force control & panic mode is still on.
Old 07-03-2016, 05:19 PM   #8
Norinradd
Drives: 2013 frs
Haha.... So the trac light on the tach should still blink?
Old 07-03-2016, 05:33 PM   #9
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I've never seen mine blink when it was turned off.
Are your tires the same size all around? I know differences in tires will make the vsc go nuts pretty easily.
murdoc is offline   Reply With Quote
Old 07-03-2016, 05:59 PM   #10
Norinradd
Drives: 2013 frs
Yah all tires are stock. The rear end lets loose as if theres the aids are turned off. But still blinks when im sideways
Old 07-03-2016, 06:11 PM   #11
Norinradd
Drives: 2013 frs
Have you got your car sideways? Haha
Old 07-03-2016, 06:14 PM   #12
justatroll
justatroll's Avatar
well tell that to @Ashikabi
http://www.ft86club.com/forums/showthread.php?t=38681
I have had mine re-enable itself after being disabled.
Old 07-03-2016, 08:00 PM   #13
86Tony
Drives: 2015 AOZORA EDITION
yes it will still blink, untill you do pedal dance then you wont see it flash
86Tony is offline   Reply With Quote
Old 07-03-2016, 08:37 PM   #14
steve99
link to pedal dance proceedure
http://www.ft86club.com/forums/showthread.php?t=25494
my understanding is
each time car switched off\on trac\vsc is full on and pedal dance is reset to normal
push buttons (short push) puts car in sport mode where your alloed a bit more slip and slide before the nannies kick in.
long push turns off more nannies and allows considerable amounts of slip\slide but the trac lights will still flash to indicate slip\slide but the system does not intervene its just an indicator that slip is occurring.
However if the system detects your rearly out of control especially over about 60 mph it will still kick in even though its "off".
The pedal dance is actually some form of test\diagnostic mode but it turns off a lot more nannies and electronic diff function, but their is still a couple left on like ice mode even with pedal dance and it appears the trac\vsc is rearly off and will not kikck back in even if it detects severe loss of control
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
ABS/Trac Slip Light (C1231/C1234) Rifle Issues | Warranty | Recalls / TSB 5 02-09-2016 06:46 PM
ABS and TRAC Light came on last night Sargy Issues | Warranty | Recalls / TSB 33 10-27-2015 04:33 AM
Car just got repaired - Is this how it's supposed to look? jarviz Scion FR-S / Toyota 86 GT86 General Forum 33 11-26-2014 05:27 PM
CEL + TRAC light... seven Issues | Warranty | Recalls / TSB 7 02-22-2013 10:52 PM
