Northwest AK, ID, OR, WA
Old 05-03-2016, 06:58 PM   #2801
Originally Posted by stockysnail View Post
All the cool kids have an oil pressure gauge. You need to man up!
I want to go old-school mechanical. I have a 0-100 that I need to test to see if it can handle startup pressure. I'll have to find a 0-150 if it gets tweaked.
Old 05-03-2016, 07:39 PM   #2802
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
She's gonna be buried for a couple minutes, mine sees 140+ if I start driving before a warm up.
I got super lucky and basically got mine from Perrin for free because of various other things that happened but I didn't say that outloud.
If you help me with a boost gauge, I'll help you with the oil pressure gauge. I need to get @Jonesy86 MAP plate so I can try drilling/tapping it so I can get a reading. If you guys pull off his supercharger, you should see if you can get the tiny bolt off the back without stripping it like I did mine for a much easier way to get a boost reading without drilling/tapping. Although if you can get mine out then I won't need to drill a MAP plate.
Doug is curious, why a boost gauge? You have a supercharger so your boost level is 100% tied to engine RPM and isn't influenced heavily by any other variables. The only time it would change is in the event of a belt snap or similar, or am I missing something? Do you have a real wideband yet?
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
RobertPaulson (05-04-2016)
Old 05-03-2016, 09:43 PM   #2803
Yikes. Good to know. I won't bother with the 100 psi gauge.
Is that why you were surprised how I drove off the other day? I figured as long as I keep it below 3K I should be ok, no?
Old 05-03-2016, 11:25 PM   #2804
Decay107
Decay107's Avatar
I'm sure, the engineers must have designed it to be flogged from cold, after all it has a relief valve set at around 140, but for me (running 30 wt) I see about 3-4X stable pressure on cold start for the first few minutes.
For reference when cold I prefer to "shift at 120psi" rather than a specific rpm, little more dynamic.
100 PSI will get you the entire warmed up operational range!
Ultramaroon (05-03-2016)
Old 05-04-2016, 01:29 AM   #2805
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Is the oil pressure gauge really that important on a stock motor for one of these? I mean I feel like the Oil Pressure Gauge and a Wideband are like, essentials, generally, just wasn't sure what others thought.
XanRules is offline   Reply With Quote
Old 05-04-2016, 01:58 AM   #2806
Decay107
Decay107's Avatar
For me, and given that it's common knowledge that oil pressure is an issue on this platform, yes an oil pressure sensor is essential. especially considering that by the time the light comes on your bearings are already toast.
I'm fine with using the built in AFR sensor for the time being though.
XanRules (05-04-2016)
Old 05-04-2016, 02:22 AM   #2807
stockysnail
Just the tip
stockysnail's Avatar
Basically the only reason is 'cause race car. No good reason really.
Old 05-04-2016, 02:51 AM   #2808
XanRules
XanRules's Avatar
Gotcha, that was really more my question was if oil pressure is an issue even in stock form with the FA20. Thanks!
Old 05-04-2016, 03:03 AM   #2809
Decay107
Decay107's Avatar
Guess it depends, if you drive relatively hard it's a good idea definitely, not so much if it's just a sporty commuter. However, smart money says @Chen would have seen something odd on a pressure gauge far before things started getting all knocky.
Ultramaroon (05-04-2016)
Old 05-04-2016, 10:54 AM   #2810
e1_griego
e1_griego's Avatar
Drives: Many
You all motivated me to add a pressure sensor lol.
I have the p3cars gauge already, just gonna add a sensor to it. We'll see how it goes.
e1_griego is offline   Reply With Quote
Old 05-04-2016, 12:15 PM   #2811
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I probably would of. I still haven't heard back from the dealer. I'll have to call them today or harass them in person tomorrow, well see.
Chen is offline   Reply With Quote
Old 05-04-2016, 01:07 PM   #2812
Yeah, @Chen's issue is exactly the reason I've been yammering on about pressure gauges. I am a fan of mechanical gauges because of their bandwidth. When the gauge flutters, interesting things are revealed like when bubbles are picked up due to sloshing or overfill.
There is one scenario in which a pressure gauge will not help; galley or orifice blockage. I don't know how they've been building them recently but the early FA20s had lots of goop slopped in places where pieces could break off like blood clots causing a heart attack. -___-
Old 05-04-2016, 01:19 PM   #2813
XanRules
XanRules's Avatar
Word, it's on my to-add list for sure. Not sure if I'll want to add the P3cars gauge and buy the sensors or just buy a separate wideband and oil pressure for the bling factor (and ability to monitor both separately). Probably the latter, but I can't find anyone who makes a matching wideband and oil pressure gauge. Smh.
Old 05-04-2016, 01:25 PM   #2814
e1_griego
e1_griego's Avatar
Drives: Many
I don't think the p3cars gauge is worth it, but it came with my car and I don't really want to add any other gauges anywhere.
It's $60 to add the oil pressure stuff using the prosport sender and wiring, plus the adapter for the galley plug.
If you're going to add a big bulky sender (like usually comes with some of the gauges) it's best to remote mount it with a 12-24" section of braided line. That way you don't run the risk of snapping the sender with vibrations and whatnot from the motor.
The Following User Says Thank You to e1_griego For This Useful Post:
NorCal (Bay Area) OFF-TOPIC Chat Thread BlaineWasHere Northern California 12912 08-18-2024 04:02 AM
Socal Off-Topic Thread #1 (Socal Chat) kayoh Southern California 102 04-20-2014 10:07 AM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
Off-topic Vladror AFRICA 1 07-29-2013 09:27 AM
