Old 04-10-2016, 12:40 PM   #1
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Vent-to-Atmosphere... Engine dying?
Had a serious oil-in-intake problem:
http://www.ft86club.com/forums/showthread.php?t=98687
Replaced Crawford AOS with RevWorks vent-to-atmosphere catch can and it shows the following at idle:
Is that real or my engine is dying? Piston rings? What else could it be?
P.S. How to embed a video on this forum?
Efferalgan is offline   Reply With Quote
Old 04-10-2016, 12:49 PM   #2
armyoffoo
Drives: 2015 Scion FR-S
I thought vent to atmosphere was really only for turbo applications, NA should be closed.
armyoffoo is offline   Reply With Quote
Old 04-10-2016, 12:53 PM   #3
Efferalgan
Sure. I've got HKS SC at 0.75 bar peak boost.
Old 04-10-2016, 12:59 PM   #4
armyoffoo
Guess it would help it I read the thread...my bad. Since your HKS boosts before the TB, it should be fine to have a vent to atmosphere model. It doesn't sound like it's idling rough, maybe it's doing that because the catch can is new?
Old 04-10-2016, 03:15 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Did you block off the inlet where the PCV normally vents into the intake manifold?
Old 04-10-2016, 06:34 PM   #6
Efferalgan
Of course. Blocked with a plug and clamped. Otherwise I would leak boost.
Old 04-10-2016, 07:47 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Time for a leak down test.
You have my condolences.
The Following 2 Users Say Thank You to Calum For This Useful Post:
Efferalgan (04-11-2016), Hyper4mance2k (06-25-2016)
Old 04-11-2016, 08:35 AM   #8
Ashikabi
Ashikabi's Avatar
Seems unlikely it's from the catch can. I suspect an unfortunate coincidence instead
Old 04-11-2016, 10:37 AM   #9
Efferalgan
Not sure I got your point
Old 04-11-2016, 10:41 AM   #10
Ashikabi
Ashikabi's Avatar
I think you have other problems. I doubt believe the catch can is causing your issue
Old 04-11-2016, 11:52 AM   #11
mrk1
Drives: Sterling BRZ Ltd
Do a compression and then leak down test.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 04-11-2016, 12:24 PM   #12
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Is that cold idle or warm?
It matters.
Is your exhaust smoking as well?
This also matters.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 04-11-2016, 03:38 PM   #13
Efferalgan
Sure, I didn't mean that the catch can is causing the problem. It just demonstrates it quite clearly.
It matters.
This also matters.
Always. Not only at idle of course. After "spirited driving" it may look like there is fire under the hood. Not sure about exhaust but it doesn't smell burnt oil.
Old 04-11-2016, 04:40 PM   #14
Calum
That Guy
Does your oil look like milk, and smell like the women's bathroom of a popular bar after a Friday night?
Turbo Kits that don't vent to atmosphere enderr Forced Induction 17 04-02-2016 12:08 PM
My battery keeps dying mynameis940 Issues | Warranty | Recalls / TSB 22 02-28-2015 11:52 PM
Negatives of unmetered BOV to atmosphere kbogarto Forced Induction 8 02-22-2015 09:03 PM
I'm dying over here! coastertrav Scion FR-S / Toyota 86 GT86 General Forum 18 04-15-2013 06:41 PM
Forum is Dying #87 Scion FR-S / Toyota 86 GT86 General Forum 49 06-08-2010 11:36 PM
