Vent-to-Atmosphere... Engine dying?
Had a serious oil-in-intake problem:
http://www.ft86club.com/forums/showthread.php?t=98687 Replaced Crawford AOS with RevWorks vent-to-atmosphere catch can and it shows the following at idle: https://youtu.be/N356yZUZSfw Is that real or my engine is dying? Piston rings? What else could it be? P.S. How to embed a video on this forum? |
I thought vent to atmosphere was really only for turbo applications, NA should be closed.
Guess it would help it I read the thread...my bad. Since your HKS boosts before the TB, it should be fine to have a vent to atmosphere model. It doesn't sound like it's idling rough, maybe it's doing that because the catch can is new?
Did you block off the inlet where the PCV normally vents into the intake manifold?
Time for a leak down test.
You have my condolences. |
Seems unlikely it's from the catch can. I suspect an unfortunate coincidence instead
Do a compression and then leak down test.
Is that cold idle or warm?
It matters. Is your exhaust smoking as well? This also matters. |
Does your oil look like milk, and smell like the women's bathroom of a popular bar after a Friday night? |
| All times are GMT -4. The time now is 09:33 AM. |
User Alert System provided by
