Drives: scion frs 2014
Jolt in AT shifting to second Gear at 7000rpm
Was wondering if anyone else has experienced this.
In 2014 firs AT in manual mode. In first gear around 7000rpm about to shift to 2nd gear, I feel a huge jolt almost as if car is stalling. Did I not shift in time or is something else going on? Sorry if this is a noob question |
#2 |
AutoX-10/10ths every run
You probably hit the rev limiter before it made the shift. On the OEM tune the rev limiter is a hard limit. It'll cause the motor to bog if you hit it.
| The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | FRSBRZGT86FAN (04-03-2016), golfyankee2121 (04-03-2016) |
#3 | |
#4 |
Drives: 2019 BMW ///M4
Do you get the feeling of the car pulling you back? If you do, I have that on my 2013 if I drive it hard in M Mode. I could also chirp in 2nd doing that (I feel like my transmission has an issue but I had it inspected recently and no issues).
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#5 |
I do feel the car pulling back. It happened only twice so far. If you have any ideas let me know
#6 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Yup, sounds like bouncing off the rev limiter to me.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#7 |
Drives: Toyota 86 GTS
This. Working as intended.
#8 |
Drives: FR-S H Lava
before concluding did jx see the rev warning red light come, exactly where the revs were if you were playing close attention to the tach, and for an AT car shouldn't you get all the way up to 7600rpm before cutoff ?
#9 |
i thought the rev was at 7000. did not see an indicator light go on. I could be wrong though. I hope it's not an issue. If it happens again, i'll be sure to update. I just wanted to see if this was an issue many people had and it seems like it is not.
#10 |
Drives: FR-S H Lava
if needed, for your peace of mind, you can just try to reproduce it. Rev it until it hits the limiter and see if it feels the same to you. No harm done
| 3rd gear jolt / clunk after smooth shift | 1Cor10:23 | Engine, Exhaust, Transmission | 2 | 03-23-2015 12:35 PM |
| Shifting from 1st-2nd gear... | FRSpappa | Engine, Exhaust, Transmission | 13 | 05-24-2014 11:06 PM |
| 3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 01:13 PM |
| Subtle Jolt when shifting into first | MethBear | Issues | Warranty | Recalls / TSB | 15 | 01-03-2014 04:01 PM |
| 3rd gear inconsistent shifting | mike the snake | Issues | Warranty | Recalls / TSB | 30 | 11-22-2013 04:54 PM |
