Old 03-22-2016, 10:27 AM   #29
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Originally Posted by JetSpeed View Post
I do not like the A/C coming-on automatically when I want heat, cold, etc. everytime I start the car. Sometimes I just want the fan NOT the A/C compressor turning on/off; wears it out in the long-in also. And "no," I did not mean de-froster.
should have got an FRS. I got a button to control my AC.
Score 1 FRS score 0 BRZ
This is why I was confused. Both the BRZ and the FR-S have an A/C button. I just hit the A/C button whether or not I want the A/C on. And I leave it on all the time, just because.
OP, be careful not to leave the A/C off for "too long." You don't want seals in the A/C system to dry out from not getting lubricated. That's when the system will start to leak.
Grimlock is offline   Reply With Quote
The Following User Says Thank You to Grimlock For This Useful Post:
go_a_way1 (03-22-2016)
Old 03-22-2016, 04:41 PM   #30
JetSpeed
Drives: 06' Forester, 15 '3.6 OBW, 16' BRZ
Yes to the seals; I understand totally. Thanks.
JetSpeed is offline   Reply With Quote
Old 03-22-2016, 05:24 PM   #31
extrashaky
Drives: 2014 BRZ Limited
Here's something else you may not realize about the air conditioner and the ECU on this car:
When you turn the A/C on, the electric fan behind the radiator starts cycling on and off. Then, between the cooling action of the fan and the temperature regulation of the thermostat, your coolant temperature will remain between 185° and 195°.
HOWEVER...
When you turn the A/C OFF, the automatic cycling of the fan turns off also, and the fan does not appear to kick on again until the coolant reaches around 210°. As long as you're moving, the air moving through the radiator will keep you between 185° and 195°. When you stop, however, your coolant temperature will start climbing until it reaches about 210°. Then the fan will kick on and keep the temperature steady.
Right now some of you are itching to respond to say, "Bullshit! I drive around all the time with my A/C off all the time, and the needle on the dash never moves from center!"
That's because the temperature gauge on your dash is fake. I wish I were kidding, but I'm not. The temp gauge climbs toward the center "normal" position, which it reaches around 170° if I recall correctly. Then it stops moving as long as the temperature is in the normal range, which is at least 170° to 210° and possibly higher. I've never overheated my BRZ, so I don't know how high it goes before the needle starts to move again.
You can test all this yourself with Torque. Set up a coolant gauge in Torque and watch the temp compared to the needle. Then turn the A/C off and just let the car idle. You'll see at least a 40° range in which the needle on the car's gauge doesn't move. You'll see your coolant temp rise pretty high with the A/C off.
I was assured by a Subaru tech that this is completely normal (take a drink) for this car. However, even knowing that, I still end up leaving the A/C on. And this could come into play as these engines age, if people ever start having cooling problems.
Old 03-22-2016, 09:10 PM   #32
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
I've got some track logs (OFT) with A/C definitely off, and my coolant temps never got over 200 degrees. Even coming off the track with low speeds, it barely came up 5 degrees.
I've got an OBDLink MX and Torque I can do some double checking, but I sincerely doubt there's a 40-50 degree temp swing.
JozhGoober is offline   Reply With Quote
Old 03-22-2016, 09:18 PM   #33
extrashaky
If you're moving, it won't go up because there's air flow without the fans. If you sit and idle, it will rise.
I just went back and checked my notes from when I first dealt with this, and I was wrong about the upper limit I witnessed. It was 210 rather than 220. I have edited my post above to reflect that. That's still a pretty good temperature swing without the needle moving at all on the dash.
Old 03-22-2016, 09:24 PM   #34
JozhGoober
I do sit and idle after coming off the track to let the oil temps come down.
I don't have much to do tomorrow, guess it's time for a little experimentation.
Old 03-22-2016, 10:03 PM   #35
ryoma
ryoma's Avatar
if you are really concerned about the coolant temps, buy an OFT and modify the fan tables. I haven't seen my coolant temp go above 200F even when stuck in traffic in 90F+ weather. cruising it's usually around 191-195 and in traffic the highest I have seen was 198F before it started cooling down. those temperatures were without the AC on. I have tweaked my stage 2 tune with the help of Wayno's guide and all is well. this is the radiator fan table taken from Wayno's guide:
the top is the stock fan table, the bottom is his modified one.
Old 03-22-2016, 11:28 PM   #36
extrashaky
Are you using the stock tune?
Old 03-23-2016, 12:04 AM   #37
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by acetothermus View Post
Honestly? Bragging rights.
I agree that it's totally pointless. In most cars it is honestly. The only vehicles I'd see it being worth while would be cars with real back seats or even third row seats.
Nope. NOOPE. Girlfriend likes it at 72+ even when its warm out. She's 95lbs and freezing all the time. I'm 190 and warm, I like to keep my side at 68 or below. Dont knock dual climate controls until you've tried it.
OK, good insight. I only have 100ish miles on the car so it's still new to me. I will give it try next time I start it up.
I WAS turning the HVAC system -completely off- since the weather is so agreeable here lately. Then, when I want the fan on, I could only (seemingly at the time) get it on by selecting AUTO , then turning off A/C. Your work-around is helpful and a great place to start.
Thank You!!
If I remember correctly, you can turn the fan on by just turning the fan speed knob. It keeps it in manual mode and won turn on the AC automatically.
Old 03-23-2016, 10:02 AM   #38
acetothermus
Drives: Flying in a Blue Dream
I have no doubt that in those situations it would be a benefit. However my self imposed "forever alone" status makes that a mute point for me.
acetothermus is offline   Reply With Quote
The Following User Says Thank You to acetothermus For This Useful Post:
go_a_way1 (03-23-2016)
Old 03-23-2016, 10:25 AM   #39
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
+1 to that! My car is my only love
acetothermus (03-23-2016)
Old 03-23-2016, 11:44 AM   #40
acetothermus
Guess there isn't much of a chance of unwanted pregnancy that way...But watch of for those friction burns.
Old 03-23-2016, 11:45 AM   #41
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
LMAO okay I am not that in love with my car, I still like girls too
Old 03-23-2016, 01:02 PM   #42
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
I too understand the harsh reality of needing to turn the A/C off EVERYTIME I need to get cool. Engineers sometimes put in hours of work in order to save a couple seconds everyday. The reprogram is definitely worth it to me.
"Wubalubadubdub! You're a wizard, Harry!"
-Captain Picard(4th incarnation of Dr. Who), Star Wars: Return of the Jar Jar
carma143 is offline   Reply With Quote
DTC Codes pleong Software Tuning 12 06-11-2016 01:17 AM
Help - Two Codes Thrown jpit Engine, Exhaust, Transmission 3 04-20-2013 12:52 AM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
What do these accessory codes mean? FastLap Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 05:56 PM
