Old 03-21-2016, 10:00 PM   #15
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Not sure how you are gona grab a rock if you can't see it but how did it get into the funnel? A rock?
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 03-21-2016, 10:01 PM   #16
Well now @Gbaby86 ......... welcome to posting to ye ol forum .......
A "rock" inside the engine is a new one on us (as far as I recall).
@steve99 , @ryoma have a couple of good ideas there (if you can see it).
Since @fumanchu1 and @go_a_way1 done used a couple of my back-in-the-day ideas ........ ......... I'll have to think on this fer ah spell.
hmmmmm........no good ideas from the old days. Back then. if it were a OHV engine, we would have simple taken off the valve cover and picked the rock out; a flathead, we would have just it lie in the bottom of the oil pan.
IF you can see it, the vac or grabber tool would be my weapon of choice.
IF you can see it and can get a rod to it ...... the redneck way would be to smash it to bits (and not worry about the bits).
If it has fallen to the bottom of the cam chain cover, I'd be tempted to just leave it there. There appears to be enough room down there for it to co-exist with the moving parts.
Sort of like a kidney stone, if it just stays put ..... there is no problem ..... but if it moves, it can cause you great pain.
go_a_way1 (03-21-2016)
Old 03-21-2016, 11:18 PM   #17
Gbaby86
Drives: 2013 Firestorm FRS 6-MT
Thanks for the welcome! Great pic humfrz. I have attempted to get the rock through the valve control assemblies that are on the front of the case. In the process I ended up pushing it down further so it's now below the bottom right pulley in humfrz' pic. I've been using a 3mm borescope but now the rock is out of sight and reach.
Possible name change since I'm the first?
RockyMotor86?
Gbaby86 is offline   Reply With Quote
Old 03-22-2016, 12:07 AM   #18
gravitylover
My money is on the ol' flip it upside down and shake it trick
Beat me to it.
Closest I've come is dropping a screw into the distributor on a 1972 Chevy Luv on the side of the road. Thing was running like shit because it was tuned at 7k feet in the Rockies and when I hit the Oregon coast it was terrible so I decided to mess with it then realized the cap was cracked and the points were burned. I should have chosen a better location or just taken it to a shop... This was two days after the throwout bearing carrier melted in Ontario Oregon and we had to replace it and the clutch disc in a parking lot without a tranny jack. I miss good old school road trips
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
go_a_way1 (03-22-2016), MTpockets (03-22-2016)
Old 03-22-2016, 12:59 AM   #19
RockyMotor86?
Well now "RockyMotor86" ...... if that rock is where you describe, I think I'd just let er lie there. It appears that even it worked its way down to the lowest point of the case it wouldn't do any harm.
Having said that, who can chime in, that actually has had that cover off and could comment on whether or not there is an oil passage down there the rock could block ..... ??
How big is the rock/pebble ... ??
Old 03-22-2016, 01:11 AM   #20
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
If anyone on here knows a shop in the Portland/Gresham area that is familar with FA20's so i could get an accurate quote that would be appriciated!
Hey man, I've got a shop recommendation for you.
VIP performance near 82nd. They were able to swap out my final drive to 4.56 in 3 hours, the owner has an 86 that he tracks. The owner wryann is Incredibly fair with his rates since he's so fast at his work, call them up!
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 03-22-2016, 02:42 AM   #21
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Coat hanger and a piece of bubblegum
Instagram: stimson
Old 03-22-2016, 03:54 AM   #22
ryoma
ryoma's Avatar
what if the bubble gum falls off... now you have gum on the bottom of your engine too lol
The Following 2 Users Say Thank You to ryoma For This Useful Post:
softgrip (03-22-2016), Tcoat (03-22-2016)
Old 03-22-2016, 11:31 AM   #23
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
You guys are thinking too far outside the box...they make tools for everything nowadays!
get yourself a car inspection camera and grabber tool (like said earlier) and a lot of patients
heres the camera I have, but you can for sure get something cheaper, around $50 to $80
http://www.canadiantire.ca/en/tools-...ontent=Default
BlueSky is offline   Reply With Quote
Old 03-22-2016, 11:38 AM   #24
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Sorry, cant help but coincidentally the dealer is taking my engine out to remove the timing cover as I type this.
So - if the front cover has to come off, the engine comes out.
Only suggestion I have is that IF you decide to do the deep dive and pay a mechanic to go in and find it: you could try to flush it out with a stream of new oil first.
If it comes out the drain plug, then story over. If it doesn't come out, where might it have gone?
justatroll is offline   Reply With Quote
Old 03-22-2016, 02:19 PM   #25
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
You can pull the timing cover with the engine in the car, I've done it to change a cam gear. Try pulling the cam position sensor, if it's small enough you might be lucky enough to have it drop through the hole. Other than that, once oil floods into that area there's a port on the head that drains back oil and the rock will go into the head and may drain down into the pan. Not 100% sure on that though.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 03-25-2016, 05:29 PM   #26
Gbaby86
Thanks for all the insight fellas. Have used a 3mm borescope with wire and all kinds of tools to try to get that damn rock out with no luck.
Thank you @Aztec! Had an appt. at PRE next friday but called Ryan over at VIP Performance and he can get me in monday at a very good rate. They're installing a perrin lightweight pulley and fumoto drain valve while they're in there
The Following 3 Users Say Thank You to Gbaby86 For This Useful Post:
Aztec (03-25-2016), LaertesSon (04-15-2016), Tcoat (03-25-2016)
Old 04-15-2016, 12:39 PM   #27
LaertesSon
LaertesSon's Avatar
Drives: Asphalt 2013 FR-S 6MT
I'm going to check for rocks every time I change my oil now..
OFT Stage 2 tune, OFH, Works AB-M, Perrin 2.75" Intake/Silicone inlet
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs
TSW Nurburgring, FIVE:AD aero kit, smoked Valenti
LaertesSon is offline   Reply With Quote
Old 04-16-2016, 01:05 AM   #28
So, @Gbaby86 ........ did they get the rock out .. ??
Portland Area- Rock in motor need advice! Gbaby86 Northwest 19 04-16-2016 03:34 AM
E85 in the Portland Area?? Aztec Northwest 5 03-16-2015 03:02 PM
WTB RIms Memphis, Little Rock area Xdragonxb0i Want-To-Buy Requests 1 02-25-2014 01:17 AM
Portland Area Wraps? Neziah Northwest 14 08-24-2012 02:03 PM
Anyone in Portland area have access to CNC milling? DarrenDriven Northwest 2 06-09-2012 02:36 AM
