Old 01-12-2016, 11:09 AM   #1
Stratoside
Stratoside's Avatar
Drives: Firestorm red MT FR-S 2013
replacement headlight unit not focused
I had to get the headlight unit on the passenger side replaced (right)and I noticed that it looks like that
Driver side (left)is the original headlight unit
is this normal..?
I went to a bodyshop
Stratoside is offline   Reply With Quote
Old 01-12-2016, 01:03 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
They probably used a non-OEM part. In general they are lower quality.
Old 01-12-2016, 01:23 PM   #3
Stratoside
Stratoside's Avatar
well the insurance probably told them to get those non oem parts... lol
o well, maybe in the future i'll replace them with HID or something
Old 01-13-2016, 01:42 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
HID will make it worse The issue is with the projectors so the only logical fix would be to bake open the headlights and swap them with good projectors in the future, either you can do that or a retrofitter can do that:
https://www.theretrofitsource.com/re...d-retrofitters
Not only will you have oem like HIDs but you will also have a nice clean legal cutoff
Old 01-13-2016, 04:31 PM   #5
ryoma
ryoma's Avatar
contact the bodyshop and clarify what headlight they used. they should have replaced it with an OEM part... and if the insurance company specifically told them to find the cheapest option, contact your insurance. there should be no reason for them NOT to replace it with an OEM part...
The Following 2 Users Say Thank You to ryoma For This Useful Post:
FRSBRZGT86FAN (01-15-2016), Mr.ac (01-13-2016)
Old 01-15-2016, 01:31 AM   #6
Zhangy
Drives: 2015 FRS
1) what happened to your car that knocked off your OEM headlight
2) your car is nearsighted now...
Zhangy is offline   Reply With Quote
Old 01-15-2016, 04:24 PM   #7
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Is the bulb actually installed correctly in the housing.....?
might want to check that...
IceFyre13th is offline   Reply With Quote
Headlight bulb replacement Alupinski Cosmetic Modification (Interior/Exterior/Lighting) 2 03-30-2015 05:02 PM
Question on series blue headlight replacement ScionOfHorus BRZ First-Gen (2012+) — General Topics 6 11-12-2014 10:11 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
Adding Fog Lights + Headlight Stalk Replacement Void Warranty? JohnAyySays Issues | Warranty | Recalls / TSB 1 05-08-2013 10:07 PM
Recommended Non Navigation Replacement Head Unit? brillo Electronics | Audio | NAV | Infotainment 3 12-18-2012 03:53 PM
