| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2015 Series.Blue BRZ
Question on series blue headlight replacement
Ate you able to keep the height adjustable xenon lights if I were to switch to the Spec-D headlights? I couldn't find anything by searching, but I am on mobile and the mobile search sucks...
Drives: none
I don't know what height adjustment you are referring to, as in does the BRZ have automatic height adjustment? That I don't know.
All modern headlight housings have adjustments you can make manually so that the beam is up enough to project onto the road ahead without being so high that its directly in the eye of oncoming traffic. If you have automatic height adjustment on the BRZ headlight and the Spec D does not mention this feature then you will lose automatic height adjustment. If you are talking about the manual height adjustment, then Spec D should have that. |
A.K.A. Starlord
I think he's referring to the ability to adjust the headlight height electronically from inside the vehicle. There is a little wheel next to the switch that dims the instruments which goes from 0-5. These positions lower the cutoff of the headlights to avoid blinding people with the low-beams when you've got junk in your trunk.
If you flip it all the way to 5 you can watch the cutoff slowly drop down to a ridiculously low level. Kind of fun :P |
#4 | |
So it's not automatic, but electronic controlled.
All BRZ's have it, and no, the Spec-D headlights don't have the motors and IIRC they take an H1 bulb, meaning they don't have HID spec projectors (so you'd get worse output)
Yeah, from a conversation I had with a guy who does vision headlights and modifications it's not worth switching from the xenon lights, so stock I stay.
Drives: Subaru BRZ Limited
Dude don't swap out the beautiful BRZ headlights.
| Replacement Windshield w/ blue shade band? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 08-27-2015 06:00 PM |
| BRZ series.blue/FRS Series 1.0 photos | Johnny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-25-2014 11:23 PM |
| Part # for 10 Series Headlight Assembly only? | FRSHunter | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-13-2014 05:03 PM |
| 10-Series Electroluminescent Dash Panel Replacement | Raiin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-18-2013 01:14 PM |
| Adding Fog Lights + Headlight Stalk Replacement Void Warranty? | JohnAyySays | Issues | Warranty | Recalls / TSB | 1 | 05-08-2013 09:07 PM |
