#85 | |
Drives: 2015 FR-S RS 1.0 #0993
Is this your 1st Subaru?
2015 Subaru WRX - SOLD!
2013 Scion FR-S - Traded In! 2015 Scion FR-S RS 1.0 - My DD , GF, and BFF! ![]() |
#86 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | radroach (11-02-2015) |
#87 |
...Just add nauseum
Drives: 2003 (AP1) S2000
Just a funny note. Toyota people feel betrayed by these failures. All the Subaru guys are saying "yep, that happens, oh well."
It's funny how the reliability of past cars from both companies have set the expectations for their respective groups. On another note, I would never have bought this car if I didn't fully intend to throw away the Subaru engine and repower the b*tch just as soon as I possibly could. This was just a funny offhand remark, don't pick it apart. I am fully aware that it's an aisin transmission, and aisin usually makes toyota transmissions, and I'm aware that the fork, bearing and snout more closely resemble Toyota AISIN units like the W and R series.
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | Ultramaroon (11-01-2015) |
#89 |
Thanks
Yea, but 4 check engine codes can worry a person. I say it's for the best. 2 hours labor to teach you a lesson to stay away from the dealer and find a good shop is well worth it. Cost me more than that
#90 | |
Drives: '13 FRS - STX
![]() Which reminds me, I think I got another coil pack CEL earlier this week that I haven't checked yet...
#91 |
Drives: Black 2013 fr-s
The probability of a "defective" bearing is exceedingly rare.
Never had one in 35 years on the road with over 20 manual transmissions. So yes, 99% of failures is driver related. If you need lessons, drive an automatic. |
#92 |
This is honestly the biggest load of garbage I've ever read. Countless upon countless of threads have been made complaining about the throwout bearing. You're going to sit there and say that none of us can drive a manual? Do a little bit of research my friend.
| The Following 3 Users Say Thank You to Brndn704 For This Useful Post: |
#93 | |
A bearing of insufficient design seems to have been installed on many Subaru's over the years. That is still the fault of the manufacturer. How many miles on your 86 oh master shifter? |
#94 |
A lot of people whine and complain on here. It means nothing.
It certainly doesn't explain the failures. Some people simply suck with a clutch. And for your info wise ass, I worked for years in a bearing factory. The company considered 1 failure per 100,000 units to be acceptable. That's 10 per one million. I'll take those odds any day of the week. I think I'm a lot more "educated" as you put than yourself. |
| The Following User Says Thank You to Canadian Greg For This Useful Post: | strat61caster (11-06-2015) |
#95 | |
Toyota Master Tech
Drives: Whiteout MT
Until the part gets redesigned, the only hope I see for a fix is in the aftermarket world. And those can be hit or miss as well. |
| The Following 3 Users Say Thank You to LavosTRD For This Useful Post: |
#96 | |
Drives: 2015 WRB BRZ Premium
For being educated, you missed the fact that bearing life is defined as L-10(or B-10) in hours or cycles. According to the above post every bearing has an infinite life except for 1 in 100,000. Thats one crazy bearing if so. The failure rate you reference is how many were out of dimensional spec after manufacturing. You obviously weren't an engineer in that factory. The TO bearing has a lifetime of X many cycles. I could make a TO bearing fail at 0 miles, just by cycling the clutch in and out. That number of cycles is reduced if the clutch I held at stoplights or for an extended period. you may even be able to simplify bearing life to the time that the clutch has spent disengaged(i.e. the TO bearing is spinning.) If you are going to correct someone, make sure you're right.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
| The Following 2 Users Say Thank You to Nickosport For This Useful Post: | MaXimus (05-02-2016), strat61caster (11-11-2015) |
#97 | |
$700 to just remove the transmission?????? Did they pull the body off the frame to get to it? Is there something about this car that is so totally different from any other rear wheel drive car that I don't know about? Is their labor rate $350 an hour?................ Another question I have is does this car really have any free play (toe play) when your foot is off the clutch? I have not been able to feel it if it does and I wonder if there isn't a design flaw with this clutch system that is making the throw out bearing continue to spin even if your foot is off the pedal. I have an 01 Saturn with over 315,000 miles on it and I have always held the clutch pedal down when at traffic lights and it is all original parts. Since there have been so many TO bearing problems with this car, I have now started to put the car in neutral when at lights, which I have never done in all my years of driving a clutch car, which is well over 45 years, with NO TO bearing failures. The fact that many of the pictures of clutch failures in these cars and the fingers on the pressure plates have turned blue/spring hub on disc is also concerning. If your a seasoned clutch driver and haven't raced the car or done burnouts etc., etc., etc.........then the fingers being blue from normal driving just doesn't seem right. If the throw-out bearing is running the whole time the engine is running and is melting, then there is another problem here and it's one that Toyota/Subaru need to fully investigate. Last edited by White64Goat; 11-11-2015 at 05:48 PM. |
#98 | |
Drives: 2014 Subaru BRZ Limited (MT)
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 03:17 AM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 09:08 PM |
| Release Bearing or Pilot Bearing | Cal3000 | Engine, Exhaust, Transmission | 11 | 01-27-2015 11:39 PM |
| Friday Ruined... | mbh1101 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 07-20-2013 02:58 PM |
| How do you know that your day is already ruined? | IloveBaldEagles | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-03-2012 10:58 AM |
